evan85 0 #1 October 14, 2014 I won't take credit for the idea since there's already an article posted about it, but wanted to start the discussion. Should skydiving rig manufacturers be looking at this design for potential use in skydiving applications? I don't know enough to give a solid answer, but my thoughts are: Pros: more efficient, more stable, etc. can't be a bad thing Cons: unnecessary cost I assume the reason this is targeted to BASE and not skydiving is that in skydiving--i.e., at terminal and where a small bit of altitude generally won't make a serious difference (unlike in BASE, or at least some BASE)--your regular old "2D" pc is going to work just fine. That said, interested to hear folks' thoughts. Is this something the skydiving manufacturers should be using? Squirrel says they have open-sourced the design (in the form of downloadable 2D patterns to print/plot and sew), so it would seem the only additional cost would be materials and labor, not R&D. Quote Share this post Link to post Share on other sites
Absolut 0 #2 October 14, 2014 Hi, i think it's actually not so much about creating more drag, that you can just achieve by choosing a bigger sized pc. I think it's more about minimizing the oszillation of the pilotchute during deployment which causes the packjob to rotate, and with that cause offheading deployments. Might be a cool thing to have on high performance canopies where this might be a bigger factor to come into play if the costs of the pc aren't too high. Not too much of a use with bigger canopies in my opinion. If might become a cool gadget, but if there is really need for that is another question. edited to add: wrote an email to squirrel requesting the cad designs, took them 2!!!!! minutes to reply, sick. next time i need a wingsuit i know where to order ;-) Quote Share this post Link to post Share on other sites
Bealio 0 #3 October 14, 2014 QuoteMight be a cool thing to have on high performance canopies I don't think that would work too well since it's not collapsible. Quote Share this post Link to post Share on other sites
Bluhdow 31 #4 October 14, 2014 The main reason for the PC design is to reduce uneven air spillage and therefore oscillation, as suggested above. In BASE jumping an oscillating PC will turn a pack job (especially at sub terminal, slider-down air speeds) and cause an off-heading. In my experience, most skydiving off-headings occur after the canopy is at line stretch sniveling and "searching" for a final heading and it pressurizes. This is not an issue with BASE canopy designs. I think for skydiving these PCs would be nice and work well, but they are certainly overkill for what we need. I'm sure they perform well in a terminal/WS BASE environment (as that's Squirrel's specialty), but I'm curious to hear some real-work feedback in slider-down applications.Apex BASE #1816 Quote Share this post Link to post Share on other sites
Alexg3265 0 #5 October 14, 2014 It's the bridle that makes a pilot chute collapse. And there aren't any collapsible pcs in base. At least that I know of. Add a kill line and viola, you have a collapsible snatch. I also requested the files and less than 2 minutes later i had them. Ditto for where I'm buying a wingsuit. Maybe two years ago I built a 6 gore semi-hemispherical PC and had to shrink it because when I hit line stretch it was like getting kicked, at 24" it worked great. Went back to 2d double circle for bulk reasons only. Lots of extra seams.....I was that kid jumping out if his tree house with a bed sheet. My dad wouldn't let me use the ladder to try the roof... Quote Share this post Link to post Share on other sites
wasatchrider 0 #6 October 15, 2014 Alexg3265It's the bridle that makes a pilot chute collapse. And there aren't any collapsible pcs in base. At least that I know of. Add a kill line and viola, you have a collapsible snatch. I also requested the files and less than 2 minutes later i had them. Ditto for where I'm buying a wingsuit. Maybe two years ago I built a 6 gore semi-hemispherical PC and had to shrink it because when I hit line stretch it was like getting kicked, at 24" it worked great. Went back to 2d double circle for bulk reasons only. Lots of extra seams..... can I have some of what your smoking?BASE 1519 Quote Share this post Link to post Share on other sites
Absolut 0 #7 October 19, 2014 Of course, but if you change it for skydiving application a collapsible version isn't too big of a deal to produce. Quote Share this post Link to post Share on other sites
Deimian 43 #8 October 20, 2014 AbsolutOf course, but if you change it for skydiving application a collapsible version isn't too big of a deal to produce. I am not sure about that. In the snatch the apex of the "top skin" might reach the apex of the mesh before being fully collapsed. Actually, because of being preshaped, I am not sure you can fully collapse it. It doesn't matter how much you pull down the apex, the edge of the "top skin" will always protrude a little bit. Quote Share this post Link to post Share on other sites
JohnSherman 1 #9 October 21, 2014 QuoteI am not sure you can fully collapse it. It doesn't matter how much you pull down the apex, the edge of the "top skin" will always protrude a little bit. That is true today on a number of pilot chutes and drogues. Quote Share this post Link to post Share on other sites
DHemer 0 #10 October 21, 2014 I do not see the point in using this for a main pilot chute as the small percentage difference in opening altitude is not doing to mean much For a reserve pilot chute though I see more potential. More drag for the same size seems like a good idea. Problem though is that if the added bulk is substantial then why not just have a larger regular reserve pilot chute. Maybe worth it on a tandem drogue? Those can bounce around a bit Bottom line is that main advantage of the Snatch is that it minimizes oscillation which I think is not that important in skydiving. Quote Share this post Link to post Share on other sites
Alexg3265 0 #11 October 21, 2014 Deimian***Of course, but if you change it for skydiving application a collapsible version isn't too big of a deal to produce. I am not sure about that. In the snatch the apex of the "top skin" might reach the apex of the mesh before being fully collapsed. Actually, because of being preshaped, I am not sure you can fully collapse it. It doesn't matter how much you pull down the apex, the edge of the "top skin" will always protrude a little bit. As it's designed sure, but extend the mesh a little bit and it'll collapse like the best of them. Imagine before you attached the top and bottom halves together, you hang them from their respective centers. If the mesh skirt hangs shorter, it will stay partially inflated, since the zp/f-111 will hang below and curl up to form a ring that will catch air. A larger bottom opening and shorter kill line will collapse it further and allow the apex and handle to pull into the skirt opening. when you hang the pilot chute collapsed from the attachment point, look at the bottom edge. If you see mesh curling in, you're good; if you see fabric curing out and up to meet the mesh, then it's not collapsing all the way. Swing it around and you'll see it catch air around the "ring" A round sketch is attached.I was that kid jumping out if his tree house with a bed sheet. My dad wouldn't let me use the ladder to try the roof... Quote Share this post Link to post Share on other sites
Alexg3265 0 #12 October 21, 2014 wasatchrider ***It's the bridle that makes a pilot chute collapse. And there aren't any collapsible pcs in base. At least that I know of. Add a kill line and viola, you have a collapsible snatch. I also requested the files and less than 2 minutes later i had them. Ditto for where I'm buying a wingsuit. Maybe two years ago I built a 6 gore semi-hemispherical PC and had to shrink it because when I hit line stretch it was like getting kicked, at 24" it worked great. Went back to 2d double circle for bulk reasons only. Lots of extra seams..... can I have some of what your smoking? Gladly! I got plenty!Actually, I'll go ahed and make one and and make it collapsible and then I'll go jump it. And then I'll post videos! And then I'll smoke more.I was that kid jumping out if his tree house with a bed sheet. My dad wouldn't let me use the ladder to try the roof... Quote Share this post Link to post Share on other sites
format 1 #13 October 22, 2014 Alexg3265 ******It's the bridle that makes a pilot chute collapse. And there aren't any collapsible pcs in base. At least that I know of. Add a kill line and viola, you have a collapsible snatch. I also requested the files and less than 2 minutes later i had them. Ditto for where I'm buying a wingsuit. Maybe two years ago I built a 6 gore semi-hemispherical PC and had to shrink it because when I hit line stretch it was like getting kicked, at 24" it worked great. Went back to 2d double circle for bulk reasons only. Lots of extra seams..... can I have some of what your smoking? Gladly! I got plenty!Actually, I'll go ahed and make one and and make it collapsible and then I'll go jump it. And then I'll post videos! And then I'll smoke more. That's the way, aha aha, WE like it! Aha, aha Quote Share this post Link to post Share on other sites
evan85 0 #14 March 5, 2015 *CALLED IT* http://squirrel.ws/skysnatch The "SkySnatch" is now available. I can see why a "more stable" pilot chute could be desirable in edge-case scenarios while wingsuiting, CRW, or similar. In freefall, I'm not sure I see any benefit. Anyone with more knowledge than me have additional insight on who, if anyone, should be looking at getting one of these? Quote Share this post Link to post Share on other sites
jakee 1,599 #15 March 5, 2015 Given that the main idea behind the Snatch is to reduce PC oscillations and the off-headings or linetwists caused by them then people who jump HP canopies and/or regularly participate in big-ways where the sky can be pretty congested on opening might be interested. That said, there is probably a far smaller portion of skydivers than BASE jumpers who would find PCs sexy enough to spend the big bucks on one Do you want to have an ideagasm? Quote Share this post Link to post Share on other sites
Lethal1ty17 0 #16 March 6, 2015 I just placed the order for my 30" skySNATCH earlier. Can't wait! I'll try to put together a short demo video showing the difference between my standard 30" ZP PC vs. the new 30" skySNATCH. Quote Share this post Link to post Share on other sites
Hellis 0 #17 March 6, 2015 Anyone else who thinks the handle looks like it has sharp edges? Quote Share this post Link to post Share on other sites
strife 0 #18 March 6, 2015 I have a few and had a collapsible made up on a 32 snatch. Edges arent really sharp Quote Share this post Link to post Share on other sites
Deimian 43 #19 March 6, 2015 Any opinions on the applicability of this design to RPC? Pilot chute instabilities don't seem that important to me except for top notch swoopers with twitchy canopies on inflation (or maybe some wingsuiters going against the general advice of avoiding elliptical canopies while wingsuiting), but I am wondering if this design can make a difference for somebody pulling their reserve handle while spinning and being close to the basement. Does it make any sense? Quote Share this post Link to post Share on other sites
jakee 1,599 #20 March 6, 2015 HellisAnyone else who thinks the handle looks like it has sharp edges? Not sharp, but the the raw CF at the edges can create some tiny splinters. Nothing a bit of fine sandpaper wouldn't solve.Do you want to have an ideagasm? Quote Share this post Link to post Share on other sites
monkycndo 0 #21 March 7, 2015 jakee***Anyone else who thinks the handle looks like it has sharp edges? Not sharp, but the the raw CF at the edges can create some tiny splinters. Nothing a bit of fine sandpaper wouldn't solve. Or some clear fingernail polish.50 donations so far. Give it a try. You know you want to spank it Jump an Infinity Quote Share this post Link to post Share on other sites
Lethal1ty17 0 #22 March 10, 2015 DeimianAny opinions on the applicability of this design to RPC? Pilot chute instabilities don't seem that important to me except for top notch swoopers with twitchy canopies on inflation (or maybe some wingsuiters going against the general advice of avoiding elliptical canopies while wingsuiting), but I am wondering if this design can make a difference for somebody pulling their reserve handle while spinning and being close to the basement. Does it make any sense? I am hoping this will be one more tool in my arsenal to jump my Nitron safely with a wingsuit, though several people already have. I'm trying to figure out my deployments and on some of my crappy ones the PC is oscillating several feet either direction causing some really off heading openings. Perhaps the more stable design of the skySNATCH will be exactly what I need. I currently use the 11' bridle from UPT. Quote Share this post Link to post Share on other sites
