cloud9
In reply to!
Ok I know I had some trouble with this when I started on this forum so I'm going to do my best to help out those still having trouble. Here's my best shot.
First you mouse click on the reply button in the thread you want to reply to. That will give you a blank page to type on. Then you scroll down and highlight the text you want to copy. You then right click on it and then click on copy. You scroll back up to the empty page. You then put a bracket and a quote like so
{quote}
then you right click your mouse and paste the text you want to reply to. then you put a bracket like so {/quote} so it should look like this. You must type quote also.
{quote} text you copied {/quote}
I used the shift key so it would show up here use the lower case bracket. But it will look just like above exactly the back slash and all. I hope this makes sense and helps out those who need it. B|
Bleau Skies
