AlMacDonald 0 #1 September 15, 2014 Does anyone have the line trim specs for a Skymaster 230? I need to check one. Thanks, al. Quote Share this post Link to post Share on other sites
Quagmirian 40 #2 September 15, 2014 Not listed on their website, but still available Quote Share this post Link to post Share on other sites
riggerrob 643 #3 September 15, 2014 PISA Skymaster 230 A line base length 13 feet A to B 2 inches A to C. 8 A to D. 17 Deployment brake setting 2 inches above the nose Full flight 12 inches above the nose B to stabilizer 6.5 C to stab. 14 D to stab. 24 Brake lines Longest outboard (UCL 5) second longest is second from wing tip (UCL4) Shortest is farthest inboard (UCL 1) Brake locking eye to toggle 19 Those dimensions were written the last time I installed a PISA-supplied line kit on a Skymaster 230 (2009). Quote Share this post Link to post Share on other sites
masterrigger1 2 #4 September 16, 2014 Quote Does anyone have the line trim specs for a Skymaster 230? I need to check one. Al, Use this. "A" Baseline= 141 5/8" A-B= 3" B-C= 7 1/2" C-D= 10 3/4" Full Flight= 8 3/4" ABOVE D Line Brake Setting= 2" BELOW C Line Use the #3 UST to determine brake setting UST's are numbered from stab to center with #1 being at the stab- #4 is toward the center. UST's 1,2,and 3 are the same length. #4 is shorter than the others by 5 7/16" Measurements are from factory drawings. Cheers, MELSkyworks Parachute Service, LLC www.Skyworksparachuteservice.com Quote Share this post Link to post Share on other sites
