wildjump 0 #1 July 27, 2014 Sewing a finger trapped line? I don't have a bar tack machine, I have a Singer 301 zigzag. It's a bear when I sew lines and it's really finnicky. I've gone through it, timed it, and tried many adjustments. I have good mechanical skills, but mixed results. What is the right feed dog, tension, and presser foot to get the best results? Pictures would help. Riggers only please. Quote Share this post Link to post Share on other sites
riggerrob 643 #2 July 27, 2014 Hint: sew together a jig. Start with 2 pieces of webbing (about the same thickness as your suspension line) 6 or 8 inches long. The webbing will give the feed dogs something to grip. Squeeze a piece of suspension line between them and sew "bridges across the ends. "Bridges" can be made of any scrap webbing. If you pay close attention to the length of the presser foot and distance between bridges. you can use that distance to set the length of your stitch pattern. Quote Share this post Link to post Share on other sites
gowlerk 2,275 #3 July 27, 2014 To begin with, a Singer 301 is a straight stitch only machine. There is no 301 zigzag. Not much detail on your problem here. What kind of line are you trying to sew, and what does it mean to be a bear? But in general Rob's suggestion to make a jig can be very helpful in two ways. It solves the problem of the line being too thin to be fed properly by the feed dogs. And it also keeps the work centred so the needle can catch it. A foot with a groove in the bottom for the line is ideal, but I've only seen this on commercial high shank ZZ feet. (you could make one with a dremel tool) Look for any ZZ machine that has a section of feed dog in the middle directly behind the needle. Tension and pressure should be as light as needed for the job, as always.Always remember the brave children who died defending your right to bear arms. Freedom is not free. Quote Share this post Link to post Share on other sites
JerryBaumchen 1,468 #4 July 28, 2014 Hi Rob, Something about a picture being worth a 1,000 words. This one is made from two layers of Type 4 on both sides & one layer transverse. JerryBaumchen Quote Share this post Link to post Share on other sites
hajnalka 0 #5 August 1, 2014 You are always so incredibly helpful on this forum ... to new, prospective and old riggers alike. Thanks. Quote Share this post Link to post Share on other sites
SkymonkeyONE 4 #6 August 5, 2014 JerryBaumchenHi Rob, Something about a picture being worth a 1,000 words. This one is made from two layers of Type 4 on both sides & one layer transverse. JerryBaumchen That is AWESOME. Thanks. Also, to the original poster: 301= straight stitch; 330= zig zag Quote Share this post Link to post Share on other sites
SkymonkeyONE 4 #7 August 6, 2014 Sorry for the brain fart. 304 is zigzag. 308 is double-throw zigzag. Quote Share this post Link to post Share on other sites
councilman24 37 #8 August 7, 2014 I.think they were talking sewing machine Model, not federal stitch code. I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
Gary73 10 #9 August 12, 2014 Since the yarns in the line weave back and forth, if necessary you can just run two passes of straight stitch about two inches long. Done it many times now; never any problems. Keep tension on both ends of the line and help it feed, and with practice you won't even need the tool mentioned above. "Extraordinary claims require extraordinary evidence." - Carl Sagan Quote Share this post Link to post Share on other sites
