jtval
b.a.s.e. questions
ive been thinking about this forever so im gonna ask it here,now.
when you base (from biulings cliffs especially) what consideration for wind(or lack there of) is there? it would seem to me that from a building you'd either be jumping into the wind, pushing you back into the bldg. or away from it where there would be a void(almost like a burble) you could jump from the side too but there are so many variables.
now from a cliff you wouldnt have much choice. what if the wind was blowing at you? do you go up another day or will tracking put you in a sasfew place? hmm.
ever hear of fjords? angel falls?
Have fun, LIVE FREE, Skydive
JT
This is closely related to the definition of the different types of BASE:
Buildings - wind blows around them
Antennas - wind blows through them
Spans - wind blows under them
Earth - wind does not blow through them
The first two are obvious - jump such that the wind blows you away from the structure. (On bridges with narrow superstructures it isn't much of an issue, though.) For cliffs it's not much of an issue unless winds are so bad that turbulence ensues, since the wind _cannot_ blow directly into or away from the cliff.
Buildings are tougher. Winds are pretty unpredictable around them. Jumping on the upwind side can be bad because of the propensity for being blown back into the building. On the sides, you get odd vortexes off the corners. On the back, you often get "contrary" winds, the same type you see blowing trash forward in the bed of a truck. I would tend to stick to light winds for building jumps.
(Disclaimer - I only have 20 BASE jumps, so don't consider me an expert.)
-bill von
