AggieDave 6 #1 January 3, 2002 For all who want, I think this should work. I embedded the site (dropzone.com) in another site on one of my domains, since I'm lazy and I don't want to actually change the setting in my firewall here at home to test it, I would appreciate it if someone who is behind a restrictive firewall would test it.The link is http://www.daves-world.com/dzLet me know. If this doesn't work, I'll try to set aside some time to actually script out something that'll work, since this is just a simple html iframe. Maybe use a Perl script or something...Oh, btw, this will only work in IE 4.x or better. If the iframe trick will work for you, but you don't use IE, then I can rescript the html later.Once you're gone, you can't come backWhen you're out of the blueAnd into the black-NeilYoung Quote Share this post Link to post Share on other sites
harro 0 #2 January 3, 2002 I am behind an Australian Govt firewall and was able to access site without issueFreemind, freesky, freebeer, freefly, freesex Quote Share this post Link to post Share on other sites
AggieDave 6 #3 January 3, 2002 Normally or through my site? I'm trying this b/c a couple people's employers have cut the site out via their firewall.Once you're gone, you can't come backWhen you're out of the blueAnd into the black-NeilYoung Quote Share this post Link to post Share on other sites
indyz 1 #4 January 3, 2002 The problem with using an iframe is that the user's browser still generates the request to dropzone.com, so a proxy will block access to the site.I just tried setting up an Apache server with the mod_proxy module. Unfortunately, the Apache module doesn't rewrite URLs in the proxied html. You can see where this could cause problems.--Brian"The sky is lovely, dark and deep.But I have promises to keep,And miles to go before I pull" Quote Share this post Link to post Share on other sites
AggieDave 6 #5 January 3, 2002 Cool, I wasn't sure what generated the request. I was trying to get this done KISS and quickly, so that's what I tried. Hmm...I'll play around with it a bit, maybe tomorrow and see what I can do. Once you're gone, you can't come backWhen you're out of the blueAnd into the black-NeilYoung Quote Share this post Link to post Share on other sites
SpeedRacer 1 #6 January 3, 2002 Ooop, NERD ALERT!Speed RacerWhat contemptible scoundrel has stolen the cork from my lunch?!-WC Fields Quote Share this post Link to post Share on other sites
harro 0 #7 January 3, 2002 Both!!Freemind, freesky, freebeer, freefly, freesex Quote Share this post Link to post Share on other sites
cyberskydive 0 #8 January 3, 2002 maybe you could just use a php include? -lol?>require ('http://www.dropzone.com');?>You would have to prolly include each link for each page individually? I have no Idea if this would work tho, its 6 am-lolfor that matter you prolly could use SSI, maybe HH would be interested in providing a mirror based on your ideas?http://www.cyberskydive.com/ Quote Share this post Link to post Share on other sites
cyberskydive 0 #9 January 3, 2002 I was able to make it kinda work at http://www.cyber.sunraydesigns.com/dropzone.phpI think if you went this route, to make it work you'd have to have some of the dz.com html code copied to your server, use absolute urls for images and any other required things, change all the links to reflect the php includes eg.http://www.yoursite.com/dz.php?go=dropzoneorhttp://www.yoursite.com/dz.php?go=forumand use something similar to the code below:#will include the basic html code for dz.comrequire('link_to_dz.com_html_code_on_your_server.txt');#will have to change links to reflect thew values in the switch#statement below. So each link would actually just include #another page from dz.com. In turn for each page you wanted #to have working, you would prolly need to have the basic #html code or perl code existing in a file on your serverswitch($dz) {case "forum": require("http://www.dropzone.com/cgi-bin/forums/wwwthreads.pl?Cat="); exit; };?>not a complete explanation by any means, but with minimal effort you should be able to do this, and make the forums work anyhow. For avid dz.com users you could start by just enabling reading /posting, at least then they could get to it from work! -lmfaohttp://www.cyberskydive.com/ Quote Share this post Link to post Share on other sites
Slappie 9 #10 January 3, 2002 I work for a company that uses "Websense" as an i-net filter. BLOCKS EVERYTHING worth a shit to see!!! So I surfed around and found a "proxy" site. There are a few you pay for and they work great at getting around firewalls and filters. There are also some good free sites. Only problem are they are slow, but they work. Try The-Cloak it has worked for me to visit some sites that my company has blocked with the i-net filter. This will also help keep your sanity. My New Website with 24hr Chat Quote Share this post Link to post Share on other sites
lummy 4 #11 January 3, 2002 Since I'm in the CompuGEEK thread, someone posted a fix a while ago that would prevent the pop up ads from the Web. Anyone remember that or use it? If so, can you repost the fix? Quote Share this post Link to post Share on other sites
jfields 0 #12 January 3, 2002 Quotesomeone posted a fix a while ago that would prevent the pop up ads from the Web.You mean, other than disabling Javascript? JustinMy Homepage Quote Share this post Link to post Share on other sites
lummy 4 #13 January 3, 2002 Hmmm... hadn't thought of that. Quote Share this post Link to post Share on other sites
cyberskydive 0 #14 January 4, 2002 I think disabling javascript is going a little overboard just to rid popup windows. there are many more uses for javascript that are widely used. The solution is to be able to control popup windows.I use a program called popup stopper. I got it free from downloads.com. Go to downloads.com and search for popup stoppers and find one suitable to your needs. Many are freeware and are usually really small programs. If I need to have a popup window open all I have to do is hold down trhe shift key when I click on a link, this way I dont have to keep getting into the browser properties.http://www.cyberskydive.com/ Quote Share this post Link to post Share on other sites
indyz 1 #15 January 4, 2002 Use a recent Mozilla (right click on image, "Block Images from this Server"). Installing Junkbuster also works very well.--Brianperl -e 'eval join " ", reverse qw/Freefaller" Another "Just print/' Quote Share this post Link to post Share on other sites
lummy 4 #16 January 4, 2002 Cool, I'll give them a try. Thanks everyone :) Quote Share this post Link to post Share on other sites
SkymonkeyONE 4 #17 January 4, 2002 As a stopgap, I have discovered Cyber's site. It is outstanding, certainly as nice as this one (my home). I am not blocked from it and happily posted away all day long. That being said, I am glad that I made it to "veteran" here before I got shut out at work. That way I won't fret when all the johnny come latelys start making their runs for stardom . I still spend nearly an hour every night checking in here and posting away. ChuckMy webpage HERE Quote Share this post Link to post Share on other sites
airann 1 #18 January 5, 2002 This forum is my favorite. But there are many that I go to.Sometimes I run into the same crowd and sometimes there are new folks. I still get harassed everywhere I go, however.http://www.AirAnn.comUgly Girl #6 Quote Share this post Link to post Share on other sites
AggieDave 6 #19 January 5, 2002 Sorry, but I'm a bit busy right now to actually sit down and script something out... There's people around on the forums with a hell of a lot more experience and programming ability then I have, so maybe they'll notice and square something away too...in the mean time maybe this'll help: http://www.anonymizer.com It may be accessable from where you work, though you probably won't beable to post, you'll beable to read.Once you're gone, you can't come backWhen you're out of the blueAnd into the black-NeilYoung Quote Share this post Link to post Share on other sites
airann 1 #20 January 5, 2002 Ok, Cybers forum is super cool.and I get to be a sugar plum fairyhttp://www.AirAnn.comUgly Girl #6 Quote Share this post Link to post Share on other sites
