AggieDave
Top Speeds
What are people's top speeds in fall rate and what position was it acheved in?
Obviously, FF head down will get higher numbers then RW, so if you know, post both. :)Me?
Sit-fly--roughly 200mph
Bell to Earth--140mph
Success is how high you bounce when you hit bottom.-General George Patton-
Uh.... get a baggier suit! Thats too fast to play with for fun dives, and still a touch fast for 4 way. For a sit at 200.... you are going to need to slow down a lot if you want to have many people play with you. I like my 148 because a skyball is at 155 and thats just an arm motion up to get to that speed. And that slow lets the floaty people play with me.
I want to touch the sky, I want to fly so high ~ Sonique
Were you thinking of me when you made this post?? ;) j/k
Umm since i only have 16 jumps i havn't tried freeflying so.
My only recorded speed was 150ish on my lvl 5 aff, i wasn't even trying.
i would have to borrow someones pro-track and do a jump of just hard arch to see what i max out at. But with a good tight (and sturdy!!!) jumpsuit i wouldn't want my suit blowing up doing 150+!! :o
I swear you must have footprints on the back of your helmet - chicagoskydiver
I'm not sure if this is right or not because I haven't seen that speed before but my ProTrack recorded a 257 on a solo hd yesterday in Z Hills. Could be something funky because it is inside my helmet and I understand they can have odd readings if mounted in there.
chopchop
PD makes canopies all day long, you only have one life, when in doubt, cut away...
