potatoman 0 #1 March 24, 2014 Was wondering if there has ever been a design where the brake line connected cells were split from the rest of the cells, on the trailing edge..... Something like an aileron on a plane wing, where the rest of the trailing edge would remain straight, and only the "control surface" would change during input. Or is there a reason for it not being split?You have the right to your opinion, and I have the right to tell you how Fu***** stupid it is. Davelepka - "This isn't an x-box, or a Chevy truck forum" Whatever you do, don't listen to ChrisD. Quote Share this post Link to post Share on other sites
piisfish 140 #2 March 24, 2014 yes it did exist, plus it is used on the huge squaresscissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
potatoman 0 #3 March 24, 2014 Any names I can look up, or pics of it.You have the right to your opinion, and I have the right to tell you how Fu***** stupid it is. Davelepka - "This isn't an x-box, or a Chevy truck forum" Whatever you do, don't listen to ChrisD. Quote Share this post Link to post Share on other sites
pchapman 280 #4 March 24, 2014 To follow up on piisfish: - modern huge cargo chute experiment Para-Flite Megafly http://defense-update.com/products/m/megafly.htm - old sport chute Para-Sled http://www.parachutehistory.com/ramair/parasled.html (Hard to see the split at the center of the trailing edge on the photo) Quote Share this post Link to post Share on other sites
leon.hill 1 #5 March 24, 2014 What you're seeing in that photo, isn't a "split" in the brakes from the canopy, you're seeing the 5 separate sections laced together. The brakes are attached normally. Quote Share this post Link to post Share on other sites
pchapman 280 #6 March 24, 2014 You are right, I didn't know what cells the brake lines attach to on the Megafly. Just that it uses splits. But I guess that is more for modularity in construction. So here are some concrete examples: For example, in a photo that can be enlarged on this page, http://www.defenseindustrydaily.com/jpads-making-precision-airdrop-a-reality-0678/, the related Gigafly ties the split trailing edge together and has brake lines that attach at points apparently unrelated to the evenly spaced split point. This appears shows something similar on the Megafly http://www.google.com/imgres?hl=en&tbm=isch&tbnid=eqcqDpkZLpjmKM%3A&imgrefurl=https%3A%2F%2Finfo.aiaa.org%2Ftac%2FAASG%2FADSTC%2FPhotos%2520and%2520Images%2FPATCAD%25202009&docid=sMkinCuaBKO8bM&imgurl=https%3A%2F%2Finfo.aiaa.org%2Ftac%2FAASG%2FADSTC%2FPhotos%252520and%252520Images%2FPATCAD%2525202009%2FTwo%252520Megaflies%252520in%252520Flight.JPG&w=1950&h=1601&ei=iFYwU6mlCpTOyAHJhoD4DQ&zoom=1&ved=0CHUQhBwwCw&iact=rc&dur=2766&page=1&start=0&ndsp=43 Quote Share this post Link to post Share on other sites
dragon2 2 #7 March 24, 2014 Not that old [inline parasled.jpg] [inline parasled1.jpg] ciel bleu, Saskia Quote Share this post Link to post Share on other sites
Boogers 0 #8 March 24, 2014 potatomanWas wondering if there has ever been a design where the brake line connected cells were split from the rest of the cells, on the trailing edge..... Something like an aileron on a plane wing, where the rest of the trailing edge would remain straight, and only the "control surface" would change during input. Good question. It does seem kind of odd that our parachutes are still inducing turns by warping the wing just like the Wright Brothers did it back in 1903. Seems like some better method would have come along since then. Maybe these split tails create more malfunctions by giving lines a crease in which to get stuck creating more line-overs? Quote Share this post Link to post Share on other sites
Quagmirian 40 #9 March 24, 2014 Except that wing warping is actually aerodynamically superior to traditional control surfaces.[citation needed] Quote Share this post Link to post Share on other sites
RiggerLee 63 #10 March 24, 2014 That's not completely true. There are limits to the performance of a single surface. There are advantages to a separate or mutable surfaces. Think faller flap. LeeLee lee@velocitysportswear.com www.velocitysportswear.com Quote Share this post Link to post Share on other sites
accumack 14 #11 March 24, 2014 Some people split the tail on the Para-Flite ParaPlanes and the Cloud it offered little to no advantage and added complexity. Also a single surface flap on the ParaPlane. Quote Share this post Link to post Share on other sites
riggerrob 643 #12 March 24, 2014 That would induce an extra vortex every time the two pieces of trailing edge were not even. Extra vortices create extra drag, but no extra lift. Quote Share this post Link to post Share on other sites
phoenixlpr 0 #13 March 25, 2014 riggerrobThat would induce an extra vortex every time the two pieces of trailing edge were not even. Extra vortices create extra drag, but no extra lift. Turn by break line is about inducing drag anyway. Quote Share this post Link to post Share on other sites
piisfish 140 #14 March 26, 2014 phoenixlpr Turn by break line is about inducing drag anyway. not only. Depending on the wings you are using, you can even turn the opposite way you are pulling scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
