darrinh 0 #1 March 1, 2014 I have 55 jumps and am putting together my first rig. Been using student gear for now. Which have Navigators in them. My rig may have same size Triathalon. Before I jump it this spring, I want to learn the characteristics. My understanding is that it will have a flatter trajectory as it is a bit of a hybrid and can be used for crew. What difference in flying normal landing patterns (no thoughts ever of swooping here) will I notice? Thoughts? Don't wanna make a mistake here and end up with broken femurs or worse. Thanks for your input Quote Share this post Link to post Share on other sites
BIGUN 1,483 #2 March 1, 2014 Quote Don't wanna make a mistake here and end up with broken femurs or worse. I write this with all sincerity... The best way to prevent broken bones is with some good one-on-one instruction at your DZ from the Instructors who can show you; rather than those who tell you over the internet. .Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
councilman24 37 #3 March 1, 2014 Opening,.stall.and flare characteristics are things you should discuss.with people.that.have jumped both. That is not necessarily your instructors.I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
wolfriverjoe 1,523 #4 March 1, 2014 You are a little bit confused. There are a couple of different Tri models. Normal, CRW and Hybrid (can be used as a normal or a CRW canopy). Big difference is the way the lines are set up, IIRC. I have a bunch of jumps on a normal 190 Tri, loaded at 1:1. I had good experience with it and liked it a lot. It's considered a "good all around" canopy, which means it does a lot of stuff, without doing any thing in particular very well. It was, for me, a good first canopy. Not too aggressive, but I could crank in a pretty good front riser turn if I leaned on it. I never tried to swoop it, and it probably wouldn't have been too good for that. It seemed to have a fairly short recovery arc. By that, I mean that it would come out of an induced dive fairly quickly. The glide was reasonably good, but I really can't compare it to a whole lot of other canopies. The flare is reportedly a bit less powerful than other canopies, but I never had a problem landing it. I've heard it said that "If you can flare and land a Tri well, then you can land anything." It was an easy to handle, forgiving canopy in my experience. I did a couple of stupid things down low with it, and it let me get away with them - One low turn had me pointed at the ground a lot steeper than I should have been, but yanking down the other side (flaring while in the turn) got me out of it. It was dumb and I don't recommend doing it. But I got away with it that one time (I learned my lesson and didn't do that again). To make it clear: This is only one person's experience, with one particular Tri. But I liked mine and was very happy with it. Usual disclaimers: Not an expert, didn't even sleep in a Holiday Inn last night. Consult your own instructors before making any decisions. Do not drive or operate heavy machinery while under a Triathlon."There are NO situations which do not call for a French Maid outfit." Lucky McSwervy "~ya don't GET old by being weak & stupid!" - Airtwardo Quote Share this post Link to post Share on other sites
faulknerwn 38 #5 March 2, 2014 An identical sized tri to a navigator will come down steeper most likely - they come down closer to a 45 degree angle than the flatter angle of the navigator. Maybe flare a tad higher than the navigator - but that's purely ideal flares for each. You may not be having perfect flares on either at this point. The triathlon is a very easy canopy to learn to be accurate with. I own 7 or so triathlons and use them as my work canopies. They open soft and fly and land well. I can get back from long distances with them easily. They do also work well for crw. And crw rocks!!!! :) Quote Share this post Link to post Share on other sites
BIGUN 1,483 #6 March 2, 2014 Quote some good one-on-one instruction at your DZ from the Instructors who can show you; rather than those who tell you over the internet. Well, err, uh, Unless, of course... Wendy shows up. Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
riggerrob 643 #7 March 3, 2014 "***... It's considered a "good all around" canopy, which means it does a lot of stuff, without doing any thing in particular very well. ..." .................................................................................... Shhhhhh! Don't tell the canopy formation (CRew) competitors ..... because some of them have won waaaaay more than their share of gold medals while hanging under Triathlons. Shhhhhh! Quote Share this post Link to post Share on other sites
mjosparky 4 #8 March 3, 2014 Quote I own 7 or so triathlons and use them as my work canopies. Greedy little lady…..I used to have a wife like that.SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
