shbuda 0 #1 March 20, 2002 I want to jump with a small sign. Something like the size of a letter page (printed on the long side "landscape") and to be photographed. Obviously it is not easy to hold something at 120MPH and also not have full use of my hands. My thoughts are to paste it to a rigid piece of cardboard (maybe even laminate it), and do my best holding it exactly downwards so it doesn't catch air. If I lose my grip (strong possibility) a piece of cardboard would float down harmlessly, anything heavier is out of the question. Of course it WILL catch air and can either spin me push me or who knows what. All I need is to be in frame on my belly have the sign and my smiley (I'm always smiling of course when skydiving...) face for a few seconds and camera clicks. Safety is first of course (I'm nearing 200 jumps) so should I practice a few time solo before involving a cameraperson.How exactly do I hold and control the sign? Where should it be on exit and before deployment?Anyways it sounds simple but is probably difficult. COMMENTS PLEASE.SHBUDA Quote Share this post Link to post Share on other sites
quade 4 #2 March 20, 2002 Have you considered the option of making a "bumpersticker" and putting it on the forehead of your helmet? You could use a cheap ProTec and still make it look kind of "special".Avery makes label stock that can be used in most printers.quadehttp://futurecam.com Quote Share this post Link to post Share on other sites
AggieDave 6 #3 March 20, 2002 QuoteObviously it is not easy to hold something at 120MPH and also not have full use of my hands. Dude, you would be very very surprised as to what you can hold onto in freefall... Try something more rigid then a single piece of cardboard, like a few layers. Don't make it too heavy, though. Definately talk to the DZO first and have him approve/disapprove the design, since anything extra you take in freefall causes the risk to go way up and the danger to people on the ground to go up (although I don't see a piece of cardboard screaming through the roof of someone's house and killing their pet monkey or something...)."I don't want to destroy your sweater, lets be friends and just walk away..." Quote Share this post Link to post Share on other sites
Jessica 0 #4 March 20, 2002 Why not a cloth sign with handholds on the bottom? I think I remember reading somewhere that that worked.No, it's not updated. Quote Share this post Link to post Share on other sites
skyhawk 2 #5 March 20, 2002 do a search this a come up a couple of times and alot of people have posted a ton of really good advice , problems etcOpinions are like a-holes everyone has one, the only one that does you any good is yours and all that comes out is shit Quote Share this post Link to post Share on other sites
PhreeZone 20 #6 March 20, 2002 Cloth works really good... Its kinda like jumping a tube (Major fun if you are experienced). I'm yet to jump a sign, but the tube makes deployment a bint.... interesting... I wish you would step back from that ledge my friend... ~3EB Quote Share this post Link to post Share on other sites
SniperCJ 0 #7 March 20, 2002 OK, finally something I have actual firsthand experience with!I have jumped with both a fabric sign with handles on the bottom and a rigid sign with handles on the back.First the fabric one: obviously a better choice for flying with as it doesnt affect your flying very much. However, it also quickly becomes unreadable due to the flapping of the fabric. If you want to try it, write your message toward the bottom of the fabric and leave 'flapping' room at the top. I put large loops on the corners that I could easily jettison if I needed to.Rigid sign: I bought a 3-ring binder with the clear 'window' on the front flap. I printed my message on standard size paper (landscape view) and slipped it into the 'window'. I attached rope nandles to the back to hold on to. This worked very well. Affects you flying to a degree, but as you said, keep it vertical and it minimizes the effect. Dont put your entire hand into the handles, just a couple of fingers. When it was pull time, I used my left hand/arm to clutch the sign to my chest and pulled. Worked fine and I could still get rid of it if I had to.Have fun, be safe and make sure you can get rid of the sign of you need to.JCPS: and the rigid sign with the window is reusable. Quote Share this post Link to post Share on other sites
AndyMan 7 #8 March 20, 2002 QuoteCloth works really good... Its kinda like jumping a tube (Major fun if you are experienced). I'm yet to jump a sign, but the tube makes deployment a bint.... interesting...The only time I've ever seen someone bounce, they had a main/reserve/tube entaglement at quincy last year.Be careful out there..._AmICQ: 5578907MSN Messenger: andrewdmetcalfe at hotmail dot com AIM: andrewdmetcalfeYahoo IM: ametcalf_1999 Quote Share this post Link to post Share on other sites
shbuda 0 #9 March 20, 2002 How about posting the a pix with your sign? Quote Share this post Link to post Share on other sites
n2skdvn 0 #10 March 20, 2002 i saw that mal at quincy too wasent prettyif ya can't dodge it RAM IT !!!!!! Quote Share this post Link to post Share on other sites
pilotdave 0 #11 March 20, 2002 A couple of friends of mine did a 2 way banner jump last December. It's a little different, but you can see pictures at http://www.inform.umd.edu/studentorg/cpsc/bannerjump.html. The camera's aim was off so the banner was at least partially cut off in all the pictures. The banner was a felt material, reinforced with webbing around the outside and across the back. It nearly tore to shreds about 10 seconds into the jump. It also flapped around too much to really read it. We're going to try again with another banner made of F111.Dave Quote Share this post Link to post Share on other sites
billvon 3,131 #12 March 20, 2002 >I want to jump with a small sign. I'd recommend one of the following:1. A piece of styrofoam insulation (the pink or blue stuff) with the message glued to it or pasted on it. Make two indentations (not holes) so you can keep a grip on it. This won't flutter, bend and wobble as much as cardboard.2. Really thick cardboard, several layers.3. A fabric sign made out of nylon (_not_ cotton, as that tends to disintegrate.)4. A piece of stiff plastic, like rig stiffener material.As you fly it make sure you are holding it as low as possible, as straight as possible. Any tilt forward and back will both drive you forward and back and make it hard to hold on to.On deployment, hold in your left hand as far away as possible, and deploy with your right. Expect it to possibly bang on your lines during opening - that's not a big deal. If anything else does happen (like an entanglement) drop it as quickly as possible.-bill von Quote Share this post Link to post Share on other sites
SniperCJ 0 #13 March 20, 2002 Hmmm, if somebody can tell me how to post the picture or if I can scan it and e-mail it to someone to post for me, I'd be happy to do it.JC Quote Share this post Link to post Share on other sites
shbuda 0 #14 March 20, 2002 I still don't get what exactly to do with my left hand on deployment. Also how should I exit, should I exit with the sign stowed under my chest strap, get stable and whip it out or exit holding on to it Quote Share this post Link to post Share on other sites
n2skdvn 0 #15 March 20, 2002 when ya make a post just check the box that saysI want to preview my post and/or attach a file. then goto the attach box and then attach your pic!!!if ya can't dodge it RAM IT !!!!!! Quote Share this post Link to post Share on other sites
SkydiveMonkey 0 #16 March 20, 2002 Some guys at my DZ did this a while ago for a photo competition in a magazine. They had the cover of the mag on a bit of chipboard or something (rigid anyway) - he was having problems staying on heading due to the size of the board, and it eventually snapped, slapping him in the face as it flew off. One tequila, two tequila, three tequila floor Quote Share this post Link to post Share on other sites
billvon 3,131 #17 March 20, 2002 >I still don't get what exactly to do with my left hand on deployment.Hold one corner of the sign in it and hold it as far away from your body as possible.> Also how should I exit, should I exit with the sign stowed under my chest strap, >get stable and whip it out or exit holding on to itExit hanging on to it. Whenever you exit with a big awkward object, make sure you're holding onto it so you can drop it if it causes serious problems (like a spin.)-bill von Quote Share this post Link to post Share on other sites
SniperCJ 0 #18 March 20, 2002 OK, lets see if this works.Here's my sign jump. JC Quote Share this post Link to post Share on other sites
skycat 0 #19 March 20, 2002 Here is one from when Brett and Brenda had thier baby girl. It was heavy cardboard paper, stapled to a piece of wood then after the hand holds were cut the bottom was wrapped with gafers tape.http://www.jumpergirl.com/pics/welcome.jpg Quote Share this post Link to post Share on other sites
shbuda 0 #20 March 21, 2002 SNIPERCJ: What an awsome picture! If you got anymore post them (also a pix of the backside of your sign although I doubt you have one) Did you feel stable and in control on freefall? Quote Share this post Link to post Share on other sites
SniperCJ 0 #21 March 21, 2002 Dude, with all the crap I was wearing on that jump 'stability' is a relative term. The helmet catching air and the pants NOT catching air made me backslide like a fiend! The camera dude gave a great effort keeping up with me.I have a couple more pics ill try ro get posted. None of the back of the sign tho. Its just 2 rope loops I ran thru holes in the front of the sign and knotted on front so they wouldnt pull thru (I added washers under the knots to keep them from pulling out).JC Quote Share this post Link to post Share on other sites
HALOjmpr 0 #22 March 21, 2002 here is the sign i jumped for WWF tickets!!!!!!course i won.............hehehehethanks cw Quote Share this post Link to post Share on other sites
Remster 30 #23 March 21, 2002 wwf tickets???and you admit that in a public forum.... lol.. RemsterMuff 914 Quote Share this post Link to post Share on other sites
HALOjmpr 0 #24 March 22, 2002 ROFL..........wasn't gonna go but local radio station was giving away tickets for the craziest thing someone would do and around here jumpin is taboo......so it gave me a reason to weasel outta rakin leaves and head to the dz!!!!!!! Quote Share this post Link to post Share on other sites
shbuda 0 #25 March 23, 2002 PLS post more sign pix... (and stories of controllability in freefall) Quote Share this post Link to post Share on other sites
