pchapman 279 #1 January 24, 2014 I had a customer's rig come in that had a quite high reserve pull force when I opened it for repack, over 35 lbs. The jumper had been to Perris Valley and the rig was covered in fine grit/dust. The reserve loop was dry & gritty to the feel, like a fine sandpaper. Just opening a flap on the rig would create a little cloud of dust. (Dust of a mineral origin, not at all like household dust.) It was a rig with a really tight loop to begin with, I think one of those "22 lbs of pull force... after leaving it overnight" deals. The loop had been well lubricated at the previous repack. (While that is normally good, if the silicone's effect is subsequently neutralized, that won't be good for pull force.) So have riggers out there seen unusual increases in pull force, due to dirty rigs? Just curious. Usually the rigs I pack aren't used in the desert, and when I have come across one that was, it was never as dust coated as this one rig. (The rig got washed before the repack!) Quote Share this post Link to post Share on other sites
DocPop 1 #2 January 24, 2014 It's possible that the hard pull was due to grit/dirt in the reserve rip-cord housing. Was it a regular steel rip-cord cable? ETA: "Well-lubricated" adds credence to my theory. More lube on the cable = more dirt stuck to it."The ground does not care who you are. It will always be tougher than the human behind the controls." ~ CanuckInUSA Quote Share this post Link to post Share on other sites
JerryBaumchen 1,467 #3 January 24, 2014 Hi Peter, I have also noticed this over the years. The first time in Australia back in '91 with a rig that I had built for a friend. He lived somewhat in the 'outback' where it was dry & dusty. I have not taken any data other than the old 'calibrated arm' method. However, if one merely gives it some thought, I do believe that your concept is valid. This should get some discussion going; and that is a good thing. JerryBaumchen PS) Re: 'The loop had been well lubricated' I have long felt that this can contribute to this situation; but I have no testing/data to verify. Quote Share this post Link to post Share on other sites
Southern_Man 0 #4 January 24, 2014 DocPopIt's possible that the hard pull was due to grit/dirt in the reserve rip-cord housing. Was it a regular steel rip-cord cable? ETA: "Well-lubricated" adds credence to my theory. More lube on the cable = more dirt stuck to it. I believe the lubricated in this instance refers to the reserve closing loop, not the reserve cable."What if there were no hypothetical questions?" Quote Share this post Link to post Share on other sites
chuckakers 426 #5 January 24, 2014 pchapmanI had a customer's rig come in that had a quite high reserve pull force when I opened it for repack, over 35 lbs. The jumper had been to Perris Valley and the rig was covered in fine grit/dust. The reserve loop was dry & gritty to the feel, like a fine sandpaper. Just opening a flap on the rig would create a little cloud of dust. (Dust of a mineral origin, not at all like household dust.) It was a rig with a really tight loop to begin with, I think one of those "22 lbs of pull force... after leaving it overnight" deals. The loop had been well lubricated at the previous repack. (While that is normally good, if the silicone's effect is subsequently neutralized, that won't be good for pull force.) So have riggers out there seen unusual increases in pull force, due to dirty rigs? Just curious. Usually the rigs I pack aren't used in the desert, and when I have come across one that was, it was never as dust coated as this one rig. (The rig got washed before the repack!) I have trouble believing someone would jump a rig so dirty that dust flies off of it when a pin cover is opened.Chuck Akers D-10855 Houston, TX Quote Share this post Link to post Share on other sites
artard 0 #6 January 24, 2014 chuckakers I have trouble believing someone would jump a rig so dirty that dust flies off of it when a pin cover is opened. I take it you've never jumped at burning man? http://www.mixcloud.com/prajna http://vimeo.com/avidya Quote Share this post Link to post Share on other sites
Liemberg 0 #7 January 24, 2014 Quote I have trouble believing someone would jump a rig so dirty that dust flies off of it when a pin cover is opened. Truman Sparks would jump a rig like that! "Whoever in discussion adduces authority uses not intellect but memory." - Leonardo da Vinci A thousand words... Quote Share this post Link to post Share on other sites
chuckakers 426 #8 January 24, 2014 artard ***I have trouble believing someone would jump a rig so dirty that dust flies off of it when a pin cover is opened. I take it you've never jumped at burning man? No I haven't. Nor have I jumped at Perris or Eloy, but if I did I would be cleaning my rig before it creates a dust cloud just from opening a flap.Chuck Akers D-10855 Houston, TX Quote Share this post Link to post Share on other sites
chuckakers 426 #9 January 24, 2014 Liemberg Quote I have trouble believing someone would jump a rig so dirty that dust flies off of it when a pin cover is opened. Truman Sparks would jump a rig like that! That scene is the first thing I thought of when I read the original post!Chuck Akers D-10855 Houston, TX Quote Share this post Link to post Share on other sites
pchapman 279 #10 January 24, 2014 chuckakers I have trouble believing someone would jump a rig so dirty that dust flies off of it when a pin cover is opened. Newer jumper, vacation trip to the US. Yeah, there was a dust cloud when I opened the main pin cover flap. It wasn't like the rig was muddy or anything. It looked relatively normal, just that the mostly black rig was slightly faded. But if you vacuumed it, you would create a distinct stripe of more intense black between two areas of 'faded' black... @ docpop: Yes it was the loop, not the ripcord cable, that was siliconed. Still, grit in the housing might increase the pull force a little bit in any case. Quote Share this post Link to post Share on other sites
johnmatrix 21 #11 January 25, 2014 What do you think might have caused it? Particle build up on the loop where the pin passes through? Maybe also on the grommet where the pin touches? Quote Share this post Link to post Share on other sites
pchapman 279 #12 January 25, 2014 johnmatrixWhat do you think might have caused it? Particle build up on the loop where the pin passes through? Maybe also on the grommet where the pin touches? Admittedly I didn't research it closely. Ideally I would have made a new loop and reclosed it right away to test the difference. Maybe it was a bit of everything, grit increasing friction where ever the pin and ripcord pressed against other structures. But it would be the loop where grit could get right into the material the most. Quote Share this post Link to post Share on other sites
dpreguy 14 #13 January 26, 2014 Opinons about dust affecting pull force are just that. Opinions. Only testing could credibly answer that question. I'm not at all in agreement that you can blame gritty desert dust for the hard pull. If it pulls hard, (greater than 22 lbs) it is most likely that the loop was simply too short to begin with. If someone does test the gritty dust's effect, then we will abide with those results. Until then, look for the usual cause of any hard pull = loop too short to allow a legal pull. Quote Share this post Link to post Share on other sites
gowlerk 2,275 #14 January 26, 2014 I recently had a customer bring me a Wings for a repack. I looked at it and admired the nicest, cleanest looking pack job I'd ever seen on a Wings. It was a larger one and and the cap was nicely sunk into the pack job. I was very impressed and wondering if would be able to do as well. Until I measured the pull force needed to open it. You guessed it....35lbs. The loop was too short, but it sure looked nice. Of course this doesn't really have anything to do with dust, and I also doubt that dust had much to do with the rig in question here. KenAlways remember the brave children who died defending your right to bear arms. Freedom is not free. Quote Share this post Link to post Share on other sites
Boogers 0 #15 January 27, 2014 pchapmangrit in the housing might increase the pull force a little bit in any case. How does one clean that? Do you run a shotgun cleaning patch through it attached to the end of a flexible cable? Blow high pressure air through it? Run water through it? Quote Share this post Link to post Share on other sites
RedundantRigger 0 #16 January 27, 2014 I know a guy who cleans them on every repack he does. He feeds flexible metal wire through the housing, then he bends the wire around a small piece of cloth. The cloth is then soaked in some kind of solvent. I believe a clean form of gasoline( he gets it at the pharmacy), it all evaporates away after. He then pulls the assembly back through the housings. Quote Share this post Link to post Share on other sites
skydiverek 63 #17 January 27, 2014 ...could it make the situation worse?: http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=4224289;search_string=british%20clean;#4224289 Quote Share this post Link to post Share on other sites
RedundantRigger 0 #18 January 27, 2014 That makes sence, I guess it could.... There where some bulletins concerning the subject: http://www.dropzone.com/news/Gear/Service_Bulletin_-_Icon_Harness_Container_Cutaway_Cable_and_Cable_Housing_569.html And also a french one, about somebody using a bad kind of oil for lubricating. Apparantly it hardend up in there or something.... But I never found it. Quote Share this post Link to post Share on other sites
riggerrob 643 #19 January 28, 2014 Parachutes de France issued that Service Bulletin because of too much "cutting oil" remaining after the housings had been formed/rolled. Quote Share this post Link to post Share on other sites
riggerrob 643 #20 January 28, 2014 dpreguyOpinions about dust affecting pull force are just that. Opinions. Only testing could credibly answer that question. I'm not at all in agreement that you can blame gritty desert dust for the hard pull. If it pulls hard, (greater than 22 lbs) it is most likely that the loop was simply too short to begin with. If someone does test the gritty dust's effect, then we will abide with those results. Until then, look for the usual cause of any hard pull = loop too short to allow a legal pull. .................................................................................. Back when I rigged in "dusty" Southern California, I test-pulled a bunch of cutaway cables. Many required a 25 pull to extract them. After cleaning, pull forces dropped to less than 5 pounds. Quote Share this post Link to post Share on other sites
sundevil777 102 #21 January 28, 2014 riggerrob***Opinions about dust affecting pull force are just that. Opinions. Only testing could credibly answer that question. I'm not at all in agreement that you can blame gritty desert dust for the hard pull. If it pulls hard, (greater than 22 lbs) it is most likely that the loop was simply too short to begin with. If someone does test the gritty dust's effect, then we will abide with those results. Until then, look for the usual cause of any hard pull = loop too short to allow a legal pull. .................................................................................. Back when I rigged in "dusty" Southern California, I test-pulled a bunch of cutaway cables. Many required a 25 pull to extract them. After cleaning, pull forces dropped to less than 5 pounds. Cleaning of the housings?People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
dpreguy 14 #22 January 28, 2014 What do cutaway cable pull problems have to do with reserve pull force? To compare these is just guessing. Quote Share this post Link to post Share on other sites
RedundantRigger 0 #23 January 28, 2014 riggerrobParachutes de France issued that Service Bulletin because of too much "cutting oil" remaining after the housings had been formed/rolled. I stand corrected! Do you have it by any chance? Quote Share this post Link to post Share on other sites
leon.hill 1 #24 January 29, 2014 dpreguyWhat do cutaway cable pull problems have to do with reserve pull force? To compare these is just guessing. Every time the cable housing changes direction (rounding over the shoulder for example), the cable inside makes contact (friction increases) and the pull force goes up. Quote Share this post Link to post Share on other sites
dpreguy 14 #25 January 29, 2014 Yes, angles/bends increase friction, but that is off topic. Angles and bends have nothing to do with the original post, implying that gritty dust was the cause of a hard pull on a rig with a stainless steel cable ripcord. I doubted that gritty dust was the cause. If the rig had a hard pull, it was probably packed too tight. Looking for untested causes is ignoring the obvious. Yes, friction is always increased with grit, and reduced with good lubrication, but to look to grit as the cause of the hard pull on the reserve was a stretch. (Actually there was no report of even finding grit in the housing. Just a dust 'poof' when the flap was whacked, or something like that. Just an example of guessing) I do not doubt the pull force examples on nylon cutaway cables before and after cleaning and lubricating, but once again, not directly translatable to a stainless steel cable situation. Lacking testing; look for the obvious cause. Quote Share this post Link to post Share on other sites
