cameramonkey 0 #26 June 12, 2002 check with the folks at www.ontrack.com. they have a decently priced util that MIGHT be able to fix your problem. they specialize in deleted files, missing partitions, etc. give it a go. they usually have a diag version that you can look but not touch to tell if you can fix your problem. that way you dont sink 150 bucks for nothing.good luck.MSN:skygilligan@hotmail.comAIM:skydiverindyICQ:7637979Yahoo:skygilligan Quote Share this post Link to post Share on other sites
lummy 4 #27 June 12, 2002 TRy what Andy said with the FDISK /MBR at a DOS prompt.... BUT don't so the sys c:... Bad Bad Juju there... You really don't want to transfer the boot floppy's system files to the C drive (unnecessary and probably cause more problems if they are not the same OS rev...)do you have another computer? Friends, Anything? Take it out and put it in there to see if you can read from it...What OS BTW? What did you format the drive as FAT? NTFS? the INTERNET comes in any color you'd like Quote Share this post Link to post Share on other sites
