nigel99 666 #1 August 29, 2013 Well a bit of a dumb question, but since I ordered the wrong thing once I need to get it right the second time! I've got a 2000 Javelin Odyssey and it is RSL ready but doesn't have the RSL. I emailed Chutingstar and ordered an RSL lanyard and just got delivered some funky RSL Universal Lanyard with Pin (that's the description on the packet). It seems I inadvertently managed to describe something that I didn't know existed and ordered it So what is an RSL lanyard for? It's basically a reserve pin with a few inches of line and a small piece of velcro. Cheers, NigelExperienced jumper - someone who has made mistakes more often than I have and lived. Quote Share this post Link to post Share on other sites
Squeak 17 #2 August 29, 2013 nigel99 Well a bit of a dumb question, but since I ordered the wrong thing once I need to get it right the second time! I've got a 2000 Javelin Odyssey and it is RSL ready but doesn't have the RSL. I emailed Chutingstar and ordered an RSL lanyard and just got delivered some funky RSL Universal Lanyard with Pin (that's the description on the packet). It seems I inadvertently managed to describe something that I didn't know existed and ordered itSo what is an RSL lanyard for? It's basically a reserve pin with a few inches of line and a small piece of velcro. Cheers, Nigel different RSL for different rigs. Some have a pin some pull the exsiting pin. My old Jav had a loop that pulled the cable and extracted the pin. Best bet would be to get it from Sunpath, give them the serial number and they'll send you the CORRECT ARE ESS ELLE You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
rwieder 0 #3 August 29, 2013 Send it to Sun Path. Best- Richard-Richard- "You're Holding The Rope And I'm Taking The Fall" Quote Share this post Link to post Share on other sites
nigel99 666 #4 August 29, 2013 Squeak ***Well a bit of a dumb question, but since I ordered the wrong thing once I need to get it right the second time! I've got a 2000 Javelin Odyssey and it is RSL ready but doesn't have the RSL. I emailed Chutingstar and ordered an RSL lanyard and just got delivered some funky RSL Universal Lanyard with Pin (that's the description on the packet). It seems I inadvertently managed to describe something that I didn't know existed and ordered itSo what is an RSL lanyard for? It's basically a reserve pin with a few inches of line and a small piece of velcro. Cheers, Nigel different RSL for different rigs. Some have a pin some pull the exsiting pin. My old Jav had a loop that pulled the cable and extracted the pin. Best bet would be to get it from Sunpath, give them the serial number and they'll send you the CORRECT ARE ESS ELLE It came from Sunpath (indirectly), they knew the model etc. I've never heard of or seen an RSL that doesn't have the snap shackle. It's no major drama, just curious what this is for... Edited to add: If you're at the dz this weekend I've got your mount.Experienced jumper - someone who has made mistakes more often than I have and lived. Quote Share this post Link to post Share on other sites
piisfish 140 #5 August 29, 2013 Is it a 9 shaped pin with the lanyard and shackle ? Not a regular straight pin ? Then you probably also need a new reserve handle and cable with th marine eye at the endscissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
koppel 5 #6 August 29, 2013 piisfishIs it a 9 shaped pin with the lanyard and shackle ? Not a regular straight pin ? Then you probably also need a new reserve handle and cable with th marine eye at the end Doubtful as the rig is pre skyhook. He just needs a standard left hand side RSLI like my canopy... ...it lets me down. Quote Share this post Link to post Share on other sites
nigel99 666 #7 August 29, 2013 koppel***Is it a 9 shaped pin with the lanyard and shackle ? Not a regular straight pin ? Then you probably also need a new reserve handle and cable with th marine eye at the end Doubtful as the rig is pre skyhook. He just needs a standard left hand side RSL Yip that is all I wanted. I'll take it to the dz this weekend as I'm curious.Experienced jumper - someone who has made mistakes more often than I have and lived. Quote Share this post Link to post Share on other sites
piisfish 140 #8 August 29, 2013 koppel***Is it a 9 shaped pin with the lanyard and shackle ? Not a regular straight pin ? Then you probably also need a new reserve handle and cable with th marine eye at the end Doubtful as the rig is pre skyhook. He just needs a standard left hand side RSLdid you see the piece of gear he has received ? By the description it is the closest I can imagine. Would be more clear with a picture. I know what he needs.scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
nigel99 666 #9 August 29, 2013 piisfish ******Is it a 9 shaped pin with the lanyard and shackle ? Not a regular straight pin ? Then you probably also need a new reserve handle and cable with th marine eye at the end Doubtful as the rig is pre skyhook. He just needs a standard left hand side RSLdid you see the piece of gear he has received ? By the description it is the closest I can imagine. Would be more clear with a picture. I know what he needs. Searched the web and this is what I got except it is from Sunpath not UPT. http://www.chutingstar.com/skydive/upt-rsl-universal-lanyard-reserve-pin I'll speak to Chutingstar, seems there was some miscommunication as I didn't ask for a reserve pinExperienced jumper - someone who has made mistakes more often than I have and lived. Quote Share this post Link to post Share on other sites
gowlerk 2,297 #10 August 29, 2013 I don't know why they call it universal. That picture shows a Vector RSL and pin used for a Skyhook. Probably the same as a Javelin equipped with a Skyhook. It is only part of the RSL, Skyhooks are somewhat complicated.Always remember the brave children who died defending your right to bear arms. Freedom is not free. Quote Share this post Link to post Share on other sites
DocPop 1 #11 August 29, 2013 If there's one thing Chutingstar is known for, it's customer service. Call them up and talk to a human - I am confident they will sort you out."The ground does not care who you are. It will always be tougher than the human behind the controls." ~ CanuckInUSA Quote Share this post Link to post Share on other sites
