freeflir29 0 #1 July 20, 2002 If you pilots out there haven't gotten these yet.... Aviation Daffynitions ALTERNATE AIRPORT: The area directly beyond the active runway when the engine quits on take off ALTIMETER SETTING: The place where the altimeter sets. Usually hidden by the control column during a near-minimums instrument approach. BANK: The folks who hold the mortgage on your aircraft. BI-PLANE: What you'll say to your bird if flying costs keep going up CARBURETOR ICE: Phrase used by pilots when explaining accident caused by fuel exhaustion. "CLEAR": Warning shouted two seconds after hitting the starter button. CONTROL TOWER: A small shack on stilts inhabited by government pensioners who can't hear. When they become blind, they are sent to centers. CRITICAL ALTITUDE: Minus six feet. CRITICAL ENGINE: That part of your airplane which used to be under the cowl, but is now in intensive care at the maintenance shop. DEAD RECKONING: You reckon correctly, or you are. DE-ICER: A device designed to operate under all weather conditions, except icing. ENGINE FAILURE: A condition which occurs when all fuel tanks become filled with air. FIREWALL: Section of aircraft especially designed to allow all engine heat and smoke to fill the cockpit. GLIDING DISTANCE: Half the distance from your present position to the nearest decent landing area at the time of complete power failure. GROSS WEIGHT: Maximum permissible take off weight, plus an extra suitcase, a case of bourbon, rifle, ammo, golf bag, bowling ball, and diving weights. HOLDING PATTERN: The term applied to the dogfight in progress over any radio facility serving a terminal airport. RANGE: Five miles beyond the point where all fuel tanks have become filled with air. WALKAROUND: What you do when waiting for weather to clear. LANDING FLAP: A 4000' roll out on a 3000' runway. Quote Share this post Link to post Share on other sites
mountainman 0 #2 July 20, 2002 Good stuff, my man! Thanks for the laugh before sleepy time.http://www.brandonandlaura.com Quote Share this post Link to post Share on other sites
