QuoteThat was my first thought too. They are REALLY nice canopies. I have two, a 129 and a 149. With my weight (250ish OTD) they are different animals. Play with different wing loadings. You'll fall in love with one of them.
QuoteWhat about a Crossfire 2? They are elliptical, have great openings and flare, and are a bit more exciting than a Sabre 2, they also have a relatively flat glide compared to something like a Katana.
A ship in the harbor is safe, but that is not what ships are built for.
I am trying to determine how this response addresses my questions at all? It doesn't.
I am a former AFF-I/Tandem/Video/Rigger. My judgment was respected and paid for. I have considered my options (at a high level) and I have ruled out the sub-100 sq ft cross-braced canopies at this point (although I have jumped them). I am looking for something a size or two more conservative than what most of my last 700 jumps were made on, and I'm getting lectured for asking about these more conservative options? Really?
Does that seem sort of silly to anyone else?
Marc
![[:/] [:/]](//www.dropzone.com/applications/core/interface/js/spacer.png)
You have (basically) described skydivings most recent fatal.
Please wait a while, use something conservative for a bit, tell us you have taken a canopy course before in the same sentance your telling us that your going to be hanging full turns close to the ground after 11 years layoff,...
then after a bit you will be telling us your choice after you have seen what is out theere...
C
Take a look at Lazlo's hit at 1.5:
http://www.youtube.com/watch?v=bJ9C0ym7WA8
Just my 2 cents, because I have a concern about the skill required and a 11 year couch time. And what you have described...
demon4o7 0
Please keep in mind - I want to be a bit more conservative because I'm not going to be as current. So 120-135 size range canopies - not sub-100 cross braced wings. Crossfire 2 has been recommended thus far. What else?
Thanks,
Marc
QuoteStilettos don't fly like most canopies out there these days. On the other hand, some people must still love them, as they are still in production. So that's still an option.
The difference between "recommendations" and "comparisons" is mere semantics within the context of my question. javascript: addTag('sly')
I just want to know what modern canopies I should consider given my significant experience with the Viper 105 and the Stiletto 107 - keeping in mind that I want to be a size or two larger and more conservative.
A Stiletto 135 would be a no-brainer, but it's old technology. After all these years, there's probably SOMETHING that flies better and has better overall handling/forgiveness even in the 120 range, right? But what?
I mean, canopies vary a lot. I had a Jonathan 136 that was "ok" but it would never surf. I had a Jedei 120 that would surf ok, but not great. I had a Jedei 105 (?) that I could surf, but not shut down softly. My Stiletto 120 was good, and so was my Viper 120 (although it opened hard). My Viper 105s were both fantastic! I over-loaded my Sabre 120, and the one time I jumped a Sabre 97 was very sketchy. With the Sabre, 135 was the right size for me. With the Stiletto/Viper 107/105 was the sweet spot. Canopies vary! That's what I'm trying to get a bead on.....
Thanks,
Marc
QuoteGotcha. I'm not trying to lecture or anything of the sort. But the title / description is somewhat misleading. Maybe "canopy comparisons" is better?
nigel99 680
DocPop 1
Swooping techniques have moved on a lot and the most recent swooping canopies (Comp Velo, Katana, Peregrine, for example) reflect the change in what modern Canopy Pilots want (mainly a steep trimmed, diving canopy which has plenty of range on the rears).
That said, if you're not going to fly that way then maybe you will prefer to stick with the Stiletto - plenty of people do still fly and love them.
If you want to try to get into the more modern way of flying a canopy for HP landings, may I suggest that you start off with a Sabre2 and build currency loading it up to say 1.5 then go to a Katana or Crossfire2 if you want something that is the next step up the performance ladder.
Be aware that these canopies will dive much more than your Stilettos and initiation altitudes will need to go up quite a bit. Finally, some coaching on new techniques would be valuable.
~ CanuckInUSA
I'm with Doc here... Don't rule out the Stiletto. It is still a very popular canopy for a number of good reasons.
"Son, only two things fall from the sky."
irishrigger 32
I am a Big fan of the stiletto, its one of the best canopys ever made in my opinion.
i have a second hand stiletto 135 if 6your interested going at a reasonable price.
rodger
ChrisD 0
Just maken a point dude,
Your the "expert" seeking advice from strangers on the internet, all I'm saying is after 11 years I'm expressing my view regarding safety and long layoffs???
C
Am I not entitled to my opinion?
Please stop by DeLand perhaps you can try the larger sized PD Peregrine?
"And please tell me WHY you are making the recommendation." :
Why am I making this reccomondation, well because of your extensive experience you might as well start with the best swooping canopy out there, why stop with someting half way when you can get the best.
Really,,,? If you were knowledgeable about your skills, then you wouldn't be asking these questions....if you are that skilled then you would know what canopy to get.......if you don't know what canopy to get because you have been gone awhile,,,then guess what,,,your skills have also been away....think
FB # - 1083
DcloudZ 0
*Back on topic
To answer the question in the OP: Not sure what your list is like right now, but if I may add my recommendations in order:
1- Crossfire 2
2- Sabre 2
3- Stiletto
4- Safire 2
Not going to talk about sizes; that's for you to consider as you know more about where you would feel comfortable. But based on your past experience and your future intentions, it seems to me that these canopies are all great for what you're looking for.
In the end the decision is yours and I'm sure you'll make the right one.
rwieder 0
Quote1- Crossfire 2
2- Sabre 2
3- Stiletto
4- Saffire 2
YES!!!!!!!!!!
"You're Holding The Rope And I'm Taking The Fall"
Bufobufo 0
A visiting jumper had a katana 135 and said I could try it and fortunately I did. 2.2WL and I was able to land it without sliding on my feet in the grass in low wind which is very helpful now when landing in 3 inches of snow in zero wind conditions ~1,9WL.
I don't recommend 2,2 WL though or you will notice it gets tough to get home from a long spot even in brakes. 1,6-1,9 somewhere is where I suspect you get the most fun out of it.
I also felt the katana was responding well when using the harness, easy to pull the fronts, acceptable on rears and the openings are exciting! :P
