palejo 0 #1 April 10, 2013 I have a set of 19" Icon risers, there are some sharp edges around the top toggle keeper and around the lower part of the front riser loops that are fraying the lower control lines in my Pilot (the lower controls lines in Pilots are made of dracon). This hard edges happen in the manufacturing process when they hot cut the webbing and burn the end threads after sewing. Any ideas or mods to remove or cover the sharp edges? I've been thinking in covering it with black gaffer tape.Alejandro B27585 Quote Share this post Link to post Share on other sites
Southern_Man 0 #2 April 10, 2013 Have you called the manufacturer to ask their advice?"What if there were no hypothetical questions?" Quote Share this post Link to post Share on other sites
palejo 0 #3 April 10, 2013 QuoteHave you called the manufacturer to ask their advice? Yes, I did. They say to take that part of the riser and rub it against a stronger fabric, like a stronger piece of webbing, and the sharpness will wear out. Another tip they game me was scissor cutting any excess of melted material that goes past the outer edge of the riser being very careful of not cutting into the webbing. I also wanted to know if some has experienced this with the icon risers or with any other risers and how they solved the problem.Alejandro B27585 Quote Share this post Link to post Share on other sites
riggerrob 643 #4 April 14, 2013 Try asking your local rigger to sew a zig-zag stitch - to hide the hard edge - then scissor-cut any hard edges still sticking out. Quote Share this post Link to post Share on other sites
Canadianfella 0 #5 April 14, 2013 Is this all new equipment? Did you purchase it all together or is it pieced together from all over? Either way, I'd be asking the mfg to send me a demo canopy ON risers, as well as a shipping label so I could send the canopy and risers that are damaged back... They should be fixing that stuff for free and returning it on them. The band-aid fix they've given you doesn't make up for the fact that their poorly manufactured equipment is damaging your gear. If they're not willing to support the product that they manufactured and sold you, get rid of it and buy gear from a manufacturer that will. Quote Share this post Link to post Share on other sites
