Deimian 43 #51 January 29, 2015 skytribeAfter some jumpers mentioned the cutaway and seeing some of the simple solutions. Myself and another rigger at DZ have built a nice cutaway system for G3. Rather than depending upon the action of the fastex clip to other implementations, this design will disconnect the chin strap completely on one side of the G3 and the helmet comes off cleanly. The cutaway handle is kept nicely in place and take 5 minutes to install. PM for more info. Interesting cutaway. Can you describe how it works and upload better pictures? It is quite blurry and I can't figure out exactly how that works. I've also installed a similar cutaway on my G3, but it relies on the skyshot cutaway http://imgur.com/a/Y10Jj. I wonder if your system has any benefit that I might consider adding to mine. Quote Share this post Link to post Share on other sites
skytribe 17 #52 January 29, 2015 The cutaway works by using a cloth loop and grommet just like the top loop on a 3 ring release. The fastex clip is secured via this cloth loop. We have tested with high loads on the strap and found it released every time with the handle only having to be moved a couple of inches. The handle is securely attached to the helmet between the shell and the liner. Whereas other solutions I've seen depend upon the action of the fastex clip being squeezed to release, this simply disconnects the clip altogether. Quote Share this post Link to post Share on other sites
Deimian 43 #53 January 29, 2015 I see better now how it works. Mine also disconnects the clip altogether, but it holds it in place replacing the original screw with a button with a spring. The main difference is that "my" system (I saw it somewhere else before) requires to widen the hole of the original screw, whereas on your case you have to replace the tape that connects one end of the clip to the shell of the helmet. Quote Share this post Link to post Share on other sites
ronny2 0 #54 January 29, 2015 Same thing but with a mini-link. Quote Share this post Link to post Share on other sites
skytribe 17 #55 January 29, 2015 Agreed, I think these are all variations on a theme and all are better solutions than a bit of line fingertrapped around the fastex clip. This would probably work MOST of the time but I'd rather have a solution that will work ALL of the time. Quote Share this post Link to post Share on other sites
dylbel 0 #56 February 9, 2015 Would it be possible to replace the fastex buckle with one of these? http://www.amazon.com/Motorcycle-Helmet-Release-Buckle-Universal/dp/B00LTJUDEE/ref=sr_1_7?ie=UTF8&qid=1423444457&sr=8-7&keywords=motorcycle+quick+release+helmet+buckle Quote Share this post Link to post Share on other sites
Deimian 43 #57 February 9, 2015 If you have a sewing machine to sew the strap I don't see why it wouldn't. But finding the pulling tab under some circumstances (cold weather, with gloves and under a canopy with lines snagged in your helmet) might be tricky. Quote Share this post Link to post Share on other sites
BrianSGermain 1 #58 February 13, 2015 Here is a simple video that will teach you how: https://www.youtube.com/watch?v=WuqJV3eRH0gInstructional Videos:www.AdventureWisdom.com Keynote Speaking:www.TranscendingFEAR.com Canopies and Courses:www.BIGAIRSPORTZ.com Quote Share this post Link to post Share on other sites
Hellis 0 #59 February 14, 2015 BrianSGermainHere is a simple video that will teach you how: https://www.youtube.com/watch?v=WuqJV3eRH0g You are not seriously promoting this idea? It's valentines day today, not april fools day. Quote Share this post Link to post Share on other sites
BrianSGermain 1 #60 February 14, 2015 It works fine, and since it is so simple to implement, more people are likely to actually do it. A perfect plan not unfolded does not save anyone.Instructional Videos:www.AdventureWisdom.com Keynote Speaking:www.TranscendingFEAR.com Canopies and Courses:www.BIGAIRSPORTZ.com Quote Share this post Link to post Share on other sites
Hellis 0 #61 February 14, 2015 BrianSGermainIt works fine And when you put tension on it? I'm quite sure it's the G3 that locks up if you put tension on the buckle before releasing it. Some buckles work but most don't. Quote Share this post Link to post Share on other sites
BrianSGermain 1 #62 February 14, 2015 With a sharp tug, it releases under tension. Regardless, I know this isn't the best possible cutaway, but it is be on Le that is most likely to be adopted by the most number of people. It is much better than nothing.Instructional Videos:www.AdventureWisdom.com Keynote Speaking:www.TranscendingFEAR.com Canopies and Courses:www.BIGAIRSPORTZ.com Quote Share this post Link to post Share on other sites
Hellis 0 #63 February 14, 2015 I don't agree. Get some thing that works under load or a different helmet. But I respect you in any thing other you say. Hope you have a sense of humor... Quote Share this post Link to post Share on other sites
BrianSGermain 1 #64 February 14, 2015 I am fine with your opposing opinion. Given substantial evidence to the contrary, I am even open to changing my oppinion. I don't need everyone to agree with me all the time. That would be too much responsibility, It is simply my hope that skydivers keep thinking deeper about safety subjects like this one. If the readers of this thread are motivated to test this method and find it unworthy, it is my hope that they did a method that does prove trustworthy to them and do it. My concern is when too much information becomes a mental overload that results in no action at all. Think, choose, think, choose...Instructional Videos:www.AdventureWisdom.com Keynote Speaking:www.TranscendingFEAR.com Canopies and Courses:www.BIGAIRSPORTZ.com Quote Share this post Link to post Share on other sites
BrianSGermain 1 #65 February 15, 2015 The cartoon was hilarious by the way, thank you for being direct with an issue that you feel is important. Your passion around this topic led me to spend time testing the G3 fastex "noose release" that I have on my own helmet. On several trials. under significant load, the method worked most of the time. What is very interesting to me, however, is that it did nt work on 100% of the pulls. I was able to get the buckle release in a single pull on 13 out of 15 tests, and was always able to get it to release in two tries. After several attempts, I eventually broke the lower half of the fastex buckle, making the release seem to work better, despite holding surprisingly well prior to release. It is possible that if one removes the lower of the two "fingers" of the fastex buckles, it will be even safer. My tests showed that this method may work for some people some of the time, and cause others to have a second pull or even a failure to release in some circumstances, especially if they are simply not strong enough to give a sharp tug in the correct direction. I will place this issue in the same category as the "Blast Handle" and "Reverse Three Rings". It can be used safety by educated personnel, however should not be considered rhe best option when other methods are available, the first being to have a snag free GoPro mount such as Cookie's Roller Mount. So, my friends, I am once again caused by the skydiving public to revisit my pervious teachings and revise my original stance. I thank you for your willingness of the skydivers to continuer solving problems, and clarify the needs for specific paradigm shifts. This is exactly how we get better as a sport. Sincerely, Brian GermainInstructional Videos:www.AdventureWisdom.com Keynote Speaking:www.TranscendingFEAR.com Canopies and Courses:www.BIGAIRSPORTZ.com Quote Share this post Link to post Share on other sites
Hellis 0 #66 February 15, 2015 Thank you for making the test and finding out how good or bad the system works. My own, very few, tests of the G3 buckle was that it failed every time. But I tested a friends helmet and was not very keen on pulling hard. If it was my own helmet I would test it till it broke and then just sew on a new buckle. I also tested two skiing helmets and my Bonehead Guner yesterday and they all worked well under load. I agree it's not the best option and it may fail. Anyone who choses to install this type of method should test it under load with their buckle and not trust whatever is written on the internet. Quote Share this post Link to post Share on other sites
clustermagnet 0 #67 December 3, 2015 So.. I figured people on this thread would be interested. Had my first snag on GoPro. ~2K jumps with one, never an issue. Getting the helmet off was almost impossible. Very lucky. I'd recommend a cutaway system :) Quote Share this post Link to post Share on other sites
tred 0 #68 December 3, 2015 what mount where you using? Quote Share this post Link to post Share on other sites
clustermagnet 0 #69 December 3, 2015 Does it matter? lol now.. on to unsubscribe from dz.com feed :) Quote Share this post Link to post Share on other sites
tred 0 #70 December 3, 2015 I wasn't trying to critique you dude, It was a sincere question for if I ever decide to put a gopro on. maybe some mounts are better than others Quote Share this post Link to post Share on other sites
clustermagnet 0 #71 December 3, 2015 tredI wasn't trying to critique you dude, It was a sincere question for if I ever decide to put a gopro on. maybe some mounts are better than others ha! it wasnt you :) I just hate this site, and bozos on it, so i wanted to unsubscribe before my inbox filled up with notifications... but unfortunately I dont see an option to stop notifications on a thread that you've replied to To answer your question, anything can get caught on any mount. There are plenty of videos that illustrate pilot chutes wrapping, even gopros going into D handles. Pretty dumb way to go in if you ask me. Get a cutaway system, and stop fucking with the box Quote Share this post Link to post Share on other sites
Squeak 17 #72 December 3, 2015 tredI wasn't trying to critique you dude, It was a sincere question for if I ever decide to put a gopro on. maybe some mounts are better than others pretty much any mount "CAN" snag. What's important here is that the G3 is not designed to come off your head easily. No cutaway system I have seen changes that. I have seen a DIY camera mount cutaway, where the base of the mount disconnects. This i thought was decent. Everything else IMO is pretty much useless.(Especially the fastex buckle and finger trap cord version). If you really want to run a camera get a helmet designed to have one on it.You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
lyosha 50 #73 December 4, 2015 Squeak***I wasn't trying to critique you dude, It was a sincere question for if I ever decide to put a gopro on. maybe some mounts are better than others pretty much any mount "CAN" snag. What's important here is that the G3 is not designed to come off your head easily. No cutaway system I have seen changes that. I have seen a DIY camera mount cutaway, where the base of the mount disconnects. This i thought was decent. Everything else IMO is pretty much useless.(Especially the fastex buckle and finger trap cord version). If you really want to run a camera get a helmet designed to have one on it. grellfab.se ;) Quote Share this post Link to post Share on other sites
Squeak 17 #74 December 4, 2015 lyosha ;) Im aware pf the Grelfab mounts and my position is unchanged. G3 is NOT a camera helmet and will not come off easily in the event of a snag.You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
nigel99 620 #75 December 4, 2015 Squeak*** ;) Im aware pf the Grelfab mounts and my position is unchanged. G3 is NOT a camera helmet and will not come off easily in the event of a snag. Losing battle squeak. Do you know how many people get helped to setup their G3 camera setup with NO discussion of snags? Full face helmet isn't the right tool for the jobExperienced jumper - someone who has made mistakes more often than I have and lived. Quote Share this post Link to post Share on other sites
