splat123 0 #1 February 17, 2013 Had a bit of a hard pull on wings freefly pud on wingsuit jump today, winter gloves probaly did'nt help, but pulling high did ! Wonder if not locating tab will make pull easier or maybe a two stage pull, down then out. First jump hop & pop felt ok. Quote Share this post Link to post Share on other sites
BIGUN 1,483 #2 February 18, 2013 Had a Wings Pud for awhile. I vote - winter gloves.Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
strife 0 #3 February 19, 2013 interesting note on the gloves, ive just got some new rigs with puds and not using gloves something to practice on the ground Quote Share this post Link to post Share on other sites
skyjumpenfool 2 #4 February 19, 2013 Practice!!! Not all gloves are equal. Choose the right gloves. Birdshit & Fools Productions "Son, only two things fall from the sky." Quote Share this post Link to post Share on other sites
mr2mk1g 10 #5 February 19, 2013 I jump a wings pud and notice no real difference when back to backing with another wings wet up with a hackey. There was always a split second bum pucker factor when my hand found something other than I was used to but there was no real difference in the pull itself IIRC. I know its common to teach a pull down/in then out motion for puds which is what I drilled when first jumping the rig but frankly I find I just pull like any other throw away deployment setup. Mine has just the one tab of folded cordura making up the tab which tucks under the right hand closing flap by the entrance to the spandex BOC. I've seen others (can't remember if later wings or other manufacturers) with other designs which may mean your experience is different to mine. I wouldn't suggest simply let the pud float free - that to me seems inviting a premi. A free-floating pud would oscillate in the wind in my mind and could work the PC out. Maybe if the mouth of the boc is tight enough you could stow it there but I'd say swapping to a hackey would be better long term if you're not getting on with the pud. Quote Share this post Link to post Share on other sites
llloyd 0 #6 February 19, 2013 QuoteWonder if not locating tab will make pull easier... The following are LouDiamonds words from an old thread. I don't know how similar the wings and UPT puds are but it might be worth looking at. "Something you might want to look at, as I use the UPT freefly handle on one of my rigs, that I found works for me. The handle has a piece of plastic sewn between the cordura that acts as a stiffener which is tucked under the lip of the container and keeps the actual handle secure and in place for freeflying. For wingsuit jumps I don't tuck that stiffener under the container flap but leave it out. The handle still stays in place and the exposed plastic gives you additional positive tactile feedback with or without gloves on. I found that with the stiffener in place under the container the pull was not as smooth as I like. However, on regular skydives I tuck the plastic under the container flap as designed.." Quote Share this post Link to post Share on other sites
splat123 0 #7 February 19, 2013 Think I am going to stick with pud for now, really like how secure it is. Had a premmy sit flying a container not suitable once, has made me VERY aware of piliot chute security. Think a lot is to do with thick gloves (roll on summer ) & not being used to pud. Will keep me pulling high for a while anyhow Quote Share this post Link to post Share on other sites
excaza 1 #8 February 19, 2013 If you're worried about security but aren't sure if you want the FF pud, you can get a tuck tab added to a different handle type pretty easily. Quote Share this post Link to post Share on other sites
