Stacy
Garbage Disposals
I find this funny. I'm on the phone with someone who infomrs me that the garbage disposal is broken. after having roommates climb under the sink, replugging it in, manually removing the garbage... etc, he finally listens to ME (the blond polish girl) and pushes the reset button.
Voila, blondie was right, and now the appliance works correctly.
did i mention that said person is a licensed plumber? :S:D
Just don't hit the red button next to that red button, *that* red button will bring an end to the universe as we know it, the other one resets the disposal. They're not labeled very well though...
If it's humming and not turning, then the motor is probably jammed. If you look underneath next to the red button that is next to the other red button that ends the universe, there is a place for an allen wrench to fit into. It should be in the center of the disposal. Unplug your disposer, then put a correctly sized allen wrench (probably 3/8" or 1/2" ) into the slot and turn the wrench in both directions to clear up the jam.
Try that and see if that works. If that doesn't work then press the blue button that will show you how deep the rabbit hole really goes....
Butthead: Whoa! Burritos for breakfast!
Beavis: Yeah! Yeah! Cool!
bellyflier on the dz.com hybrid record jump
If it's humming now, that means it's probably jammed. You should have a tool that came with the garbage disposal to fix this, it looks like (actually it probably is) an allen wrench. Put the wrench in the hole in the middle of the garbage disposal and turn to free whatever is jammed.
Good luck.
Jim
"Like" - The modern day comma
Good bye, my friends. You are missed.
but how about the Green button that is next to the red button which is next to the other red button that will bring the end to the universe? i think that button plays Neil Diamond songs :D:ph34r:
PCSS # 1 Rookeskydiver
"Its a Wonka Bar"....."Go ahead Charlie open it, lets see that golden ticket"
I am not going nowhere near my gabage disposal. The little people live in it....
Are you talking about the little people that multiply when you thow water at them?
Dude, c'mon seriously, you gotta lay off the crack :P
