Abedy 0 #26 November 21, 2012 Quote Using the same pliers, try now to cut a Spectra reserve closing loop and you will see it's another story. That's all correct and understood... ya sorta missed my THREE statements about the SUCCESSFUL demonstration of an UNtightened (loose hanging) reserve loop being cut? The sky is not the limit. The ground is. The Society of Skydiving Ducks Quote Share this post Link to post Share on other sites
RiggerLee 63 #27 November 21, 2012 So it wont let me up load the video here but I found another spot on the web site to up load it. It will be under "loop cut 1" and "loop cut 2" in missolanious. It looks like it will have to go through some kind of approval process, probable checking for kiddi porn, but it shud be up soon. Boringest vid ever for any non rigger. In any case keep an eye out. LeeLee lee@velocitysportswear.com www.velocitysportswear.com Quote Share this post Link to post Share on other sites
nigel99 660 #28 November 21, 2012 Quote Quote Using the same pliers, try now to cut a Spectra reserve closing loop and you will see it's another story. That's all correct and understood... ya sorta missed my THREE statements about the SUCCESSFUL demonstration of an UNtightened (loose hanging) reserve loop being cut? You should have called your thread "Cypres cuts loop" to highlight the pointExperienced jumper - someone who has made mistakes more often than I have and lived. Quote Share this post Link to post Share on other sites
skydiverek 63 #29 November 22, 2012 Quote Quote Using the same pliers, try now to cut a Spectra reserve closing loop and you will see it's another story. That's all correct and understood... ya sorta missed my THREE statements about the SUCCESSFUL demonstration of an UNtightened (loose hanging) reserve loop being cut? GUYS!!! Here it is: http://www.youtube.com/watch?v=-Jf3NV5wLWw Quote Share this post Link to post Share on other sites
Abedy 0 #30 November 22, 2012 Quote You should have called your thread "Cypres cuts loop but due to my f*ckin' cam I didn't get around to taping it so I will at least show the one with a ripcord being cut" to highlight the point FIFY OK, would have been a loooooooooooooooooooong subject, but heck... The sky is not the limit. The ground is. The Society of Skydiving Ducks Quote Share this post Link to post Share on other sites
RiggerLee 63 #31 November 22, 2012 Ok, vids are up as loop cut 1 and loop cut 2 if you go to the video area http://www.dropzone.com/videos/Miscellaneous/loop_cut_2_2406.html http://www.dropzone.com/videos/Miscellaneous/loop_cut_1_2405.html So what you're seeing there is a Vigil cutter wired into our computer. There's a fuse in parillel with it. You'll see the fuse blow and the cutter fire cutting the loop. It's a 500 lb vectran loop. The thin wire runs through the cutter giveing the computer feed back on the release of the main. You'll also see a pin puller being activated at the same time although it's macanicaly slower. At the top of the frame you can just see the top of the recovery section. This is the setup we used on the last flight in early nov. LeeLee lee@velocitysportswear.com www.velocitysportswear.com Quote Share this post Link to post Share on other sites
nigel99 660 #32 November 22, 2012 Quote Quote You should have called your thread "Cypres cuts loop but due to my f*ckin' cam I didn't get around to taping it so I will at least show the one with a ripcord being cut" to highlight the point FIFY OK, would have been a loooooooooooooooooooong subject, but heck... or simply 'boobies' and the clip, you'd have got more hits....Experienced jumper - someone who has made mistakes more often than I have and lived. Quote Share this post Link to post Share on other sites
