No. The goal is to get a reserve that can be jumped in the same wind conditions as the main. Your personal wind maximum may be lower, but there are plenty of skydivers who are comfortable jumping their highly loaded main canopies in winds of 25mph or more. A smaller reserve would be a better match for those conditions than a larger reserve. A serendipitous benefit would be a reserve that plays nicer with the main in the unlikely event of a two-out.
Mark
I would assert that the justification is to get a reserve that can be jumped in the same wind conditions as the main. I would venture that the goal is to get a reserve that packs in the same volume as the main for cosmetic reasons.
You mention jumping in winds in excess of 25 mph. If you need a wing loading of in excess of 2/1 to have a rigid wing in the conditions then these guys must be jumping in wind more in the range of 40 mph, I really doubt that's the case. At 1.5 or 1.6 with a wing that's loaded toward the front (not designed for light front riser pressures), you're going to be rigid in wind to 30 plus, depending on gusting. But then if it's gusting 10 to 35, you're not going to have much certainty in a descent landing on any wing under any loading in my opinion.
I can not see any hard surface landing at 2.2 done without pilot input being something that's not going to require a trip to the hospital.
Interesting none the less. What we ("we" as in not me) won't justify in order to look good.
Martin
Experience is what you get when you thought you were going to get something else.
AC DZ
AC DZ
QuoteQuoteQuoteFor both 23d and 23f, manufacturers can choose to TSO at any weight equal to or greater than 220 pounds/100kg.
Mark,
Did you mean a Maximum operating weight or test weight?
Maximum operating weight. Test weight is maximum operating weight x 1.2.
Mark
Thanks That's what I thought.
Sparky
Mark
