DYEVOUT 0 #1 January 31, 2003 forward: The Perfect Dump -- Every once in a while, each of us experiences a perfect dump, it's rare, but a thing of beauty in all respects. You sit down expecting the worst, but what you get is a smooth sliding, fartless masterpiece that breaks the water with the splashless grace of an expert diver. But that's not the end of it. You use some toilet tissue only to find that it was totally unnecessary. It makes you feel that all is right with the world and you are in perfect harmony with it. The Beer Dump -- Talk about nasty dumps. Depending on the dumper's tolerance, the beer dump is the end result of too many beers. it could have been 2 or 22, it doesn't matter. What you get is a sinister, lengthy, noisy dump accompanied by a malevolent fog that could close a bathroom for days. The Chili Dump - Hot when it goes in, and rocket fuel when it leaves. The chili dump stays with you all day, making your tush feel like a heat shield. The Cable Dump -- Long, curly and perfectly formed like 2 feet of E13 telephone CO-axial cable. It loops lazily around the bowl, like a friendly serpent. You wonder admiringly, ''DID I DO THAT? Where did it come from?'' you leave the bathroom pleased with yourself. The Latrine Dump -- In case you didn't know, a latrine is a hole in the ground with a tent around it where soldiers, boy scouts and flies go to dump. Tip: Don't ever, ever look in the hole. The Mona Lisa Dump -- This is the masterpiece of dumps. It's as perfectly formed as it can be. Delicate and slender with intricacies that would make da Vinci weep. And just think, you made it yourself. You may even want to break out the Polaroid, but maybe that's going a bit too far. The Empty Roll Dump - You're done...you reach for the toilet paper only to discover that empty cardboard cylinder. A mild panic begins coldly in your throat. You could use the curtains...no, someone would say ''Where are the curtains?'' Then what would you say? The rug?...too cumbersome. Then you must come to the same conclusion that every ''empty roll dumper'' must face...Pull up your slacks, tighten your tush and wriggle yourself to the nearest full roll. The Splash-Back Dump - You send the dump on its way, it drops like a depth charge into the bowl creating a column of cold bowl water that washes your bottom with a startlingly unpleasant shock. Now you're wet and embarrassed. Tip: Blot instead of wiping. The Aborted Dump - You are in mid-dump when the phone rings. What do you do? ABORT! Pinch it off, go for the phone, and save the rest for later. It isn't pretty, but you've gotta do what you gotta do. The Alfresco Dump -- Everyone has had to go outdoors from time to time. This can be a rather pleasant experience really. The open air, the nature, and a good bush all contribute to the peaceful ambiance that our primitive forefathers must have enjoyed. What can screw up this harmonious interlude is a troop of Brownies or a patch of poison ivy. The Childbirth Dump -- This is a dump that is simply too big to go through the aperture provided by nature for the purpose. You sit there, thinking over your dilemma. First it hurts, and it isn't going to get any better. You wonder if you'll ever see your loved ones again. You imagine the newspaper headlines screaming ''Man dies trying to hatch monster loaf.'' You realize you'll have to resolve the crisis before you can leave the bathroom. Basically there are only three things you can do: Scream, call an Obstetrician, or just hope like hell have enough Vaseline to get you through it. The Tijuana Trot Dump -- The phrase ''Shit Happens'' really applies here in a big way. When the ice in your tainted margarita makes contact with your lower intestinal tract, the fun begins. For the next 72 hours you'd be better off if you carried your own portable toilet with you because you will spend most of that time on the pot and the rest of the time in a fetal position. Now you realize why Mexico never had a navy. The Machine Gun Dump -- You're just sitting there in a state of sublime peace when all of a sudden you emit a group of noisy gassy bursts that break the silence like machine gun fire. The guy in the next stall hits the floor like a combat veteran, cradling his umbrella like an M16 and shrieking something about “damn Commies.” The Sound Effect Dump -- You feel a noisy one coming on. Relatives, friends or work mates are within earshot, so you must employ some clever techniques to cover the disgusting sounds you are about to emit. Timing is obviously very important here. At the precise moment of release, try the following sound effects: flush the toilet, sing the first two stanzas of your national anthem, or drop a handful of quarters on the floor The Security Dump -- You have enough on your mind when you're in the bathroom without worrying about a lockless door and someone bursting in to find you in mid-dump mode. So how can you prevent this embarrassing spectacle from taking place? One way is to strategically place your foot against the door. If you can't reach to do this... hum loudly. The Cling-On Dump -- For the most part you've completed your dump, but there's one little morsel that refuses to drop off. You're getting impatient. Someone else wants to use your stall. So, you grip the seat with both hands and wriggle, twist and pump but that last little stubborn piece just hangs there, suspended, clinging like a canned peach between you and the bowl water. Maybe the person pounding impatiently on the door has scissors. The Houdini Dump -- You go, then you stand up to flush, and the darn thing has disappeared. Where'd it go? Did it creep down the pipe? Did you dream the whole thing? Is it lurking out of sight? Should you wipe...maybe you should just to make sure you went. Should you flush? You'd better, because if you don't, you know it will reappear and smile at the next person who comes in. The Flu Dump -- You feel so bad that you don't know which end of you to put down first. You have roaring cramps, so you sit down. Then a wave of nausea rolls over you like a cold fog, so you stand up and cramps squeeze your intestines like a vice so you sit down again...up down up down. Don't you wish Mom were close by? The Porta-Pottie Dump -- Construction workers and outdoor concert goers will tell you about going in a portable toilet. My best description would be, “It's like taking a shit in an upright coffin.” It's claustrophobic and it smells bad... best advice... go in a paper cup. The Proctologist Dump -- In the beginning, the Lord created the earth, the sky and the firmament, but I hope he didn't create this dump, because there is nothing biblical about it -- you run out of gas. That's right, you run out of propulsion. The dump is right there at the end of your barrel and refuses to go any further. You grunt, you squeeze, you wriggle but it just stays there like a lump of lead. You've only got two choices here. One is to squeeze the damn thing back up your intestine and wait until next time. The other is to pretend you're a proctologist and go after it yourself. Not a pretty picture is it?? The Whole Roll Dump -- No matter how much you wipe, it doesn't seem to be enough. You blow the whole roll and you have to flush 25 times too. The whole episode is consumer waste. The Graffiti Dump -- You flush the dump and the swirling motion of the receding bowl water forces the dump to the porcelain sides, scraping a creative squiggle on its way down. You flush again but the curlicue hangs there...love it or leave it. Its your choice. The Encore Dump - Ahhhh, you're done, so you wipe, put yourself together, wash your hands and are about to vacate the bathroom when you feel another dump coming. You have to return for a curtain call. The world's record is seven encores. The Born Again Dump - This is a dump that's going so badly, you say “Lord, if I live through this, I'll take up religion.” You always get through it, but seldom keep the promise you made in desperation, because a born again dump is like childbirth... you forget the pain quickly. ----------------=8^)---------------------- "I think that was the wrong tennis court." Quote Share this post Link to post Share on other sites
mattb 0 #2 January 31, 2003 Construction workers, outdorr concert goers, and skydivers at boogies . . . . Quoteforward: The Porta-Pottie Dump -- Construction workers and outdoor concert goers will tell you about going in a portable toilet. My best description would be, “It's like taking a shit in an upright coffin.” It's claustrophobic and it smells bad... best advice... go in a paper cup. reply] Quote Share this post Link to post Share on other sites CrazyIvan 0 #3 January 31, 2003 There is one more: The IN-A-HURRY dump: You are doing something important and you have to take a dump, you rush to the bathroom, drop your pants, BLAST IT, and leave it doesn't matter if you're done, some shit left your body, that's all it matters.__________________________________________ Blue Skies and May the Force be with you. Quote Share this post Link to post Share on other sites JJohnson 0 #4 January 31, 2003 Sorry bro. There is nothing so important as to leave shit stuck on your body....... JJJJ "Call me Darth Balls" Quote Share this post Link to post Share on other sites CrazyIvan 0 #5 January 31, 2003 QuoteSorry bro. There is nothing so important as to leave shit stuck on your body....... JJ I agree, but I've seen it happen. When I take a dump I TAKE A DUMP!!!__________________________________________ Blue Skies and May the Force be with you. Quote Share this post Link to post Share on other sites phatcat 0 #6 January 31, 2003 Quote I've seen it happen. I don't even want to know dude... Quote Share this post Link to post Share on other sites CrazyIvan 0 #7 January 31, 2003 Quote Quote I've seen it happen. I don't even want to know dude... I mean...I've seen a guy rush in and out the can...don't get me wrong __________________________________________ Blue Skies and May the Force be with you. Quote Share this post Link to post Share on other sites wmw999 2,589 #8 January 31, 2003 Apparently in Germany, it's common for toilets to have little platforms to catch your deposit, and leave it there to be inspected until it's flushed. I think that prevents the splashback, too. That would give you a whole new opportunity for analysis. heh heh. she said "anal". heh heh Wendy W.There is nothing more dangerous than breaking a basic safety rule and getting away with it. It removes fear of the consequences and builds false confidence. (tbrown) Quote Share this post Link to post Share on other sites DYEVOUT 0 #9 January 31, 2003 Oh, man That would reek !! Half the reason for the water is odor control. A healthy beer/sauerkraut load could potentially cost you your life, if it doesn't get underwater quick ! ----------------=8^)---------------------- "I think that was the wrong tennis court." Quote Share this post Link to post Share on other sites Meathorse 0 #10 January 31, 2003 Ooooo, thanks DYEVOUT.... Just in time for lunch too! Quote Share this post Link to post Share on other sites jumperconway 0 #11 January 31, 2003 Thanks a lot man, I was going to the dz today but don't think I can jump with the condition of my ribs after that! That's the shittiest thread I've read yet. I'm afraid to go to the bathroom now for the fear of over analyzing it! Quote Share this post Link to post Share on other sites bigben 0 #12 January 31, 2003 Oh dear: http://www.ratemypoo.com/ -Ben Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
