adamhildreth 0 #1 September 9, 2012 Hi, I've been looking at the UPT specs on what size canopys you can fit in different vector rigs and I can't find one that fits a 190 tight but will downsize to a 150? Do they do one? I can see 210 to 170. Ideally I'm looking for a container that will fit 190 - 150. Quote Share this post Link to post Share on other sites
tbrown 26 #2 September 9, 2012 Call somebody at UTP. Seriously, how the heck would any of us know ? Your humble servant.....Professor Gravity ! Quote Share this post Link to post Share on other sites
adamhildreth 0 #3 September 9, 2012 Oh sorry I thought I'd posted in a Gear forum where people have a LOT of knowledge on this...? I will call UPT and ask, if however someone does know then please shout. Quote Share this post Link to post Share on other sites
Nicolai 0 #4 September 9, 2012 Currently own a v 348, have had a sabre2 190 in it.. It's a tight fit though. Not sure I would do it again. It's made for a 170 and will fit a 150 as well. But really... My personal opinion is to get a container sized for the canopy You are planning on stuffing in it. Otherwise it's going to be a bitch to pack(especially if new)... Futhermore It won't look good... Quote Share this post Link to post Share on other sites
ChrisClark 0 #5 September 9, 2012 A lot will depend on the size of reserve that you require and the type of main canopy, not all 190s are the same volume. Try this online sizing calculator. http://vos.uptvector.com/vos/v3sizing.html Quote Share this post Link to post Share on other sites
milehigheric 0 #6 September 9, 2012 Ditto.... Learning to pack can be a bitch, don't make it harder on yourself. I have a 'loose' fitting canopy in my rig and it was still a bitch to get the hang of packing newish zp. Quote Share this post Link to post Share on other sites
Joellercoaster 6 #7 September 10, 2012 What you try and cram into your main pack tray is up to you. You could possibly get that range of canopies in there if you are really keen and a strong packer, though it might not be recommended. I have a V347, and I've had things between 129 and 170 in there. The 170 was frankly a bitch to pack. But the most important consideration is what goes in the reserve container. If you are jumping a 190 main, then a smaller reserve (and that's likely, if you want that big a range of main sizes) is not a brilliant plan. As the saying goes, do you really want your first jump on the smallest canopy you've ever flown, to be when you're high on adrenaline from a chop and probably lower than you've ever opened before? Me either.-- "I'll tell you how all skydivers are judged, . They are judged by the laws of physics." - kkeenan "You jump out, pull the string and either live or die. What's there to be good at? Quote Share this post Link to post Share on other sites
gowlerk 2,296 #8 September 10, 2012 The short answer is no. If you try this you will not be happy with the fit of either the 190 or the 150. And you will have to make unsuitable compromises on the reserve sizing. I understand why you might like to try this, but realistically you will need to go through two sets of gear in your progression through these sizes. It also may happen that you will get to 170 or so and decide to stay there. I did, for 18 years now. KenAlways remember the brave children who died defending your right to bear arms. Freedom is not free. Quote Share this post Link to post Share on other sites
Electronaut 0 #9 September 10, 2012 Want some knowledge on this? Canopies can vary in their pack volume by up to 10%, so if you have your reserve and your main on the high side of this variable, you're going to have a bear of a time getting your main closed. Also, the deployment bags for the reserve and main can vary in their material thickness and how much they add to the total volume of the pack job. Add in the differences of packing in different climates, if you're in a dry climate, packing can be a bit more difficult. This isn't even touching the fact that your reserve when jammed in there tight is going to piss off your rigger. If you have a main total malfunction, it may very well take your reserve longer to extract as the two packjobs are crammed together. A tight main can also stretch and screw up the container over time. Quote Share this post Link to post Share on other sites
adamhildreth 0 #10 September 10, 2012 Excellent - really good feedback thanks. Everything else i've heard is that containers generally take a size up and size down from their 'regular' pack. To be honest I would be happy with something that took a 190 and eventually a 170. Quote Share this post Link to post Share on other sites
vitriol 0 #11 September 10, 2012 Some canopies pack one size smaller. That could help you fit up to 3 or 4 different sizes canopies in the same container. Optimum reserves pack about one size smaller than regular reserves if I'm not mistaken, and the same is true for at least 2 other brands. I own a PD pulse main canopy, and it packs much smaller than a Storm of the same size. I know other canopies from other brands also pack smaller, but I have no experience with them, maybe other people could tell you more. Just make sure with your rigger that your container is not overly tight; that could cause problems. Quote Share this post Link to post Share on other sites
gowlerk 2,296 #12 September 10, 2012 QuoteTo be honest I would be happy with something that took a 190 and eventually a 170. Excellent idea and probably the best way for you to go.Always remember the brave children who died defending your right to bear arms. Freedom is not free. Quote Share this post Link to post Share on other sites
matt3sa 0 #13 November 6, 2012 Upt would know best, but my experiences were as follows.... When I started skydiving I bought a V348 and stuffed a 170 in it. I eventually had a stiletto 150, a crossfire 139, a cobalt 135, and then Velocity 120 in it (all using the same 170 d-bag). I never had any deployment issues. As I got smaller I had to reduce the length of the closing loop. If you buy something that is suited for a 190 you shouldn't have any issues downsizing to a 150. Quote Share this post Link to post Share on other sites
ShcShc11 0 #14 November 6, 2012 QuoteUpt would know best, but my experiences were as follows.... When I started skydiving I bought a V348 and stuffed a 170 in it. I eventually had a stiletto 150, a crossfire 139, a cobalt 135, and then Velocity 120 in it (all using the same 170 d-bag). I never had any deployment issues. As I got smaller I had to reduce the length of the closing loop. If you buy something that is suited for a 190 you shouldn't have any issues downsizing to a 150. http://www.unitedparachutetechnologies.com/PDF/CHART_00037___Rig_Sizing_Chart.pdf Thinking about purchasing a Vector too... Is "Full Fitting" (e.g: putting a 170 in a V348) a bitch to pack? Cheers! Shc Quote Share this post Link to post Share on other sites
babz 0 #15 November 6, 2012 I've got a Pilot 168 in a V348, with a PDR 160. At first it was a bit of a bugger to get it in the bag, but I dont really notice it now - however the container does look pretty tight. It'd be interesting to try and get something like a Pulse 190 in there to see how it compares to the bulky pilot. Quote Share this post Link to post Share on other sites
theonlyski 8 #16 November 6, 2012 Quote Thinking about purchasing a Vector too... Is "Full Fitting" (e.g: putting a 170 in a V348) a bitch to pack? I have a Safire2 169 and an Optimum 176 in my V348 and it isn't difficult to pack at all, even when the canopy was brand new. Also had a Sabre2 170 in there for a bit, again, no issues."I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
blueblur 0 #17 November 6, 2012 Vector told me directly the V350 will work for a 190-150. From their rigger's mouth. So that's what I have on order!In every man's life he will be allotted one good woman and one good dog. That's all you get, so appreciate them while the time you have with them lasts. - RiggerLee Quote Share this post Link to post Share on other sites
dirtbox 0 #18 November 6, 2012 it may or may not matter to you but think about comfort - I am jumping a 306 with two canopies. The pilot 117 is the tight fit and the rig is very brickish and not super comfy. The other canopy is a Sensei 91 of the ZPX variety and is on the soft side but is super comfy. Something to think about. Quote Share this post Link to post Share on other sites
stephd23 0 #19 November 7, 2012 I got a new v310 and have a sabre2 150 and optimum 160 in it. Both full fit and have no troubles packing it, altho my 150 has around 800 jumps on it i wouldn't want to be packing a brand new canopy in it though. if you go full fit, get a well used 170! Quote Share this post Link to post Share on other sites
waveoff5500 0 #20 November 7, 2012 i have a v306 (made for a 120) and i managed to get a 135 in there but it was a pain and im a very good packer. on the flip side it fits a 120 perfectly. it was to the point where there had to be no air left or it wouldnt fit. not really fun so i would recommend getting a properly sized container."its just a normal day at the dropzone until its not" 1653 Quote Share this post Link to post Share on other sites
