TitaniumLegs
Viso vs. Viso 2
So, I ordered a Viso 2, and what showed up was a Viso (1). I've been searching for a comparison of the two, both here (using search and scrolling through page after page of this forum) and on L+B's site. Finally resorted to downloading and comparing both manuals.
As far as I can tell:
- Viso2 has a "Daily Jump Counter" that "Displays number of jumps completed on last date and/or 9 other jump dates."
- Odd looking button or LED on the edge that isn't defined in the manual.
Does anybody know of a definitive comparison or other details I didn't find?
Should I bug the dealer to swap it?
Thanks!
(>o|-<
If you don't believe me, ask me.
I would get the newer version if that is what was advertised, or return it, or perhaps some money back.
I believe the old version doesn't have the soft rubberized coating. That is nice in that it adds friction to help keep it in the fabric pockets of helmets.
The "button" is actually not a button, but the location of where the optional (you must get that version) optical interface port would be if you had bought the version that has that feature. It is just a dummy receptacle cover if it is not that version.
I thought it possible that the newer version was water resistant, and the old version was not. It is very possible my memory is wrong about the old version not being water resistant.
I was not aware about the jump counter difference you mentioned.
People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am
I think your thinkin of the optima audiable not the viso which is a digital visual altimiter.
Yes, the Viso doesn't have the optical port, and of course you don't put a Viso in a helmet.
OK, so what's that little white bump on the side in both of these pictures (Viso 2, not original Viso)?
http://www.l-and-b.dk/products/visual/viso_ii
http://www.dropzone.com/gear/Detailed/619.html
(>o|-<
I don't know, maybe it covers the little filter that needs to be replaced if you dunk it in water.
Are you talking about the reset button the side?
Reset button is on the back next to the battery. I'm talking about the white bump visible in both pictures I linked above.
Pg 55 in the manual:
The VISO II is water resistant.
The Air Filter is the white circular part mounted on the side of the unit. If it becomes wet (after a splash in the swoop pond) then let the VISO II dry in a warm place for 48 hours.
Note: The Air Filter must be replaced if jumping is resumed quickly or if the VISO II has been submerged into water.
Air Filter removal tooling kit is an accessory which can be purchased separately.
http://www.l-and-b.dk/downloads/manuals/pdf/visoII/VISOII_Manual_040909.pdf
