daytripper419 0 #1 August 15, 2012 I am seeking out what a preferred microphone set up is for gopro. Having trouble with audio during tandem interviews not being quite loud enough. Thanks justin Quote Share this post Link to post Share on other sites
IanHarrop 42 #2 August 15, 2012 i found this http://polarprofilters.com/feat/gopro-microphone/"Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy Quote Share this post Link to post Share on other sites
RyanFYF 0 #3 August 16, 2012 are you using the open back or the closed back plate on the housing. You should be using the open back one, and they make a nice muffle pillow that ataches to it for max sound with minimal wind noise. you could even make one http://www.ioffer.com/i/2-x-foam-windscreens-wind-noise-reducer-for-gopro-hd-508696311 Quote Share this post Link to post Share on other sites
mjosparky 4 #4 August 16, 2012 Quoteare you using the open back or the closed back plate on the housing. You should be using the open back one, and they make a nice muffle pillow that ataches to it for max sound with minimal wind noise. you could even make one http://www.ioffer.com/i/2-x-foam-windscreens-wind-noise-reducer-for-gopro-hd-508696311 ClickyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
TheRealOps7 0 #6 August 18, 2012 that muffle pillow looks quite similar to the filter pads used in fish tanks... http://www.aquariumguys.com/pure-power-multi-use-foam-pad-20ppi-13in-13in.html Quote Share this post Link to post Share on other sites
