shibu
Noob Question
On my first tandem, the camera man had a plate on his helmet with a 35mm (film camera) on one side and a large camcorder on the other (I think it took full sized VHS tapes).
Cameras have gotten alot smaller since then.
Why is it that the cameras aren't mounted inside the helmets (like audibles)? It seems like the large mounting surface on some of the flat top camera helmets would offer enough room to put a small camera inside of it.
Just seems like it would be safer to have everything exposed as little as possible.
If you mean like the NVertigo-X and the MXV (below it)... Then, yes, there are several side-mount helmets to choose from. There are those who (as in your case) have been vidiots for a verrrrrry long time and what they have works for them AND there is no reason to buy new at this time. Given that a camera rig, helmet, etc. can be north of a grand.. That's a lot of ramen noodles for the poor bloke who makes a living at doing video.
Nobody has time to listen; because they're desperately chasing the need of being heard.
Point taken re the cash. Although it is not cheap for students, I have always felt instructors & camera men are underpaid for what they do.
But what I meant was why can't you take a helmet like the Camera Pro (from Exit Composites) http://www.square1.com/manufacturers/square1/p443.asp#NVertigo-X
and mount a small camera INSIDE the helmet so it is fully enclosed.
Just a note, my cam man was not a v idiot... it is just that my 1st tandem was in ~1992.
You mean like this? http://www.actionhelmetcameras.com/camera-helmets/2k-composites/ff3-freefly-helmet/
Old idea.
Lots of camera jumpers change cameras more often helmets. The various external mount systems offer much more versatility.
The first inside the helmet camera helmet was in the 90's.;)
I'm old for my age.
Terry Urban
D-8631
FAA DPRE
Most pro (and amateurs) videots jump digital cameras now that record the video on an a solida state drive. The high quality cameras are still too large to fit inside normal helmets: you'd still have a side or top box sticking out. There are lens that can be plugged into a input port of camera, but these lens capture analog video (unless there's a new one out there)
Remster
Agreed!
Ever since Robin Sutherland died from a snagged camera late 1980s) I have only jumped with enclosed cameras.
Currently I jump a Sidewinder that 90 percent encloses my Sony video camera.
As to why more cameramen don't enclose their cameras ... basically, we do not kill enogh to keep the risk in the news, so that younger cameramen believe that line snags are not a risk. The primary change over the years has been the trend towards smaller cameras, which present SMALLER snag points.
I knew the quality of those cameras were lower but I didn't realized they were analog.
I guess as technology changes, we will start to see tiny HD cameras that can fit into a helmet.
HD is not the only thing that matters.
Remster
It wouldn't be unreasonable to figure out how to carve space for some go-pro HD cameras inside something like maybe a FTP, I just don't see it happening.
The quality wouldn't be the same as the CX and DSLR, though the go-pro's are getting pretty good these days, I still don't see myself replacing my gear for them.
"I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly
DPH -7, TDS 578, Muff 5153, SCR 14890
I'm an asshole, and I approve this message
