JerryBaumchen 1,485 #276 October 4, 2014 Hi Quag, Quote a good cutaway setup PM with photos sent, Jerry Baumchen Quote Share this post Link to post Share on other sites
Quagmirian 40 #277 October 5, 2014 I've got them, thanks. It looks interesting. Quote Share this post Link to post Share on other sites
freekflyguy 0 #278 October 5, 2014 Can you forward them to me Quag.It's nice to be important, but it's more important to be nice. Quote Share this post Link to post Share on other sites
RiggerLee 63 #279 October 5, 2014 I'm also curious. LeeLee lee@velocitysportswear.com www.velocitysportswear.com Quote Share this post Link to post Share on other sites
freekflyguy 0 #280 October 5, 2014 RiggerLeeI'm also curious. Lee Not as curious as me, it's probably me that will be using it :-)It's nice to be important, but it's more important to be nice. Quote Share this post Link to post Share on other sites
RiggerLee 63 #281 October 5, 2014 Better you then me. Not loving that design. LeeLee lee@velocitysportswear.com www.velocitysportswear.com Quote Share this post Link to post Share on other sites
mkael 0 #282 October 6, 2014 Looks nice this is going forward. Anyway post pictures. Regarding the earlier issues about inlets and stuff There is an entire paper linked written about this issue http://www.flyozone.com/paragliders/en/learn/ozone-sharknose-technology/ Then of course the earlier debates about rod rigidification or not. In hindsight all the issues were manageable and those fishing rod nightmares wings were flown by very few people. I sort of agree the position of the a-lines has an effect on how the wing feels in turbulence. http://www.dhv.de/web/en/safety/articles-statistics/plastic-rods-yes-or-no Bottom surface shape? people with paramotors like to use reflex profile wings Quote Share this post Link to post Share on other sites
Quagmirian 40 #283 October 15, 2014 RiggerLeeBetter you then me. Not loving that designI plan on using some kind of setup which requires no modification of the normal rig. I have a harness with the cutaway system still on. Perhaps we could build some sort of belly container? [inline HPIM4415_small.jpg] Last of the materials and more sewing. [inline HPIM4435_small.jpg] [inline HPIM4437_small.jpg] [inline HPIM4438_small.jpg] Quote Share this post Link to post Share on other sites
pchapman 280 #284 October 15, 2014 Quagmirian I have a harness with the cutaway system still on. Perhaps we could build some sort of belly container? Some people will just exit back to wind holding a bag and pilot chute. DZO's might not like the risk of that if it isn't a really high tailed aircraft. Others might have someone else IAD them out the door, so they can concentrate on the exit while someone else handles doing a clean deployment. Or someone might have the bag set up as a direct bag that someone holds while the jumper exits. Leaving aside the pros and cons of each method, with my cutaway harness, I wanted to get rid off any sort of loose bag and pilot chute in the airplane or any requirement for trained assistance in the plane. Therefore I used the cut-off main container to construct a belly container. Since it was awkward to use the top flap which was so integrated into the reserve bottom flap, I built a new custom top flap. Pretty much just cordura and some plastic for the stiffener. No need for binding tape, just folded edges, since it wasn't going to get a lot of use. The main container then just had loops to tie or hook it to tie down points on the cutaway harness. They don't have to be structural of course, but just keep the belly container in place and allow you to swing it open on one side to allow getting into the harness. The risers enter the belly pack at open slots at the top corners and I did put some velcro closures there to keep things in place. The risers of course go down from the 3 rings on the cutaway harness, down one's chest and into the belly pack. I didn't consider them to be too much in the way, especially when one is normally just doing a back to wind hop and pop with no more than a few seconds freefall. But I also put some 'wraps' with a little bit of velcro closure along the cutaway harness main lift webs, so the risers could be partially covered and secured on the way down to the belly pack. Oh yeah, the cutaway handle:I built a new cutaway handle/ cable to be a big white loop handle so its colour and shape is different from the nearby pillow on the regular rig I'd be wearing. I wanted that for intentional spinning mal tests. Velcro was added to the chest strap so the cutaway handle could be moved to a central position if desired. (The cable length and flexibly mounted end of the cutaway cable housing worked ok for that on my particular cutaway rig.) Since the container for the 3rd canopy is the old main container, it still had the BOC on it. So one could exit on one's back and just do a left handed pull on the BOC. The closing loop anchor changed to be from the bottom flap to the backpad/top flap area. This allows a large variation in canopy size by varying the closing loop length, while still providing pin tension. The whole system isn't fancy but is adequate. Quote Share this post Link to post Share on other sites
Quagmirian 40 #285 October 22, 2014 I'm having fun with making a lineset; it's not something I've done before. I don't have any sort of table or tension device so I'm having to guess what 5 lbs is. Seems to be working so far, with the A lines within about ±5mm [inline line_loops_small.jpg] Quote Share this post Link to post Share on other sites
riggerrob 644 #286 October 22, 2014 Wow! That is way neater than my first line set! Keep up the good work. Quote Share this post Link to post Share on other sites
freekflyguy 0 #287 October 22, 2014 Were they done on my bartacker?It's nice to be important, but it's more important to be nice. Quote Share this post Link to post Share on other sites
Quagmirian 40 #288 October 22, 2014 freekflyguyWere they done on my bartacker?They were done on my home machine. Two rows of straight stitch and a row of zigzag makes for a nice looking 'fake' bartack. Pure zigzag gets a bit crowded on my machine. Quote Share this post Link to post Share on other sites
hackish 8 #289 October 23, 2014 I've enjoyed following this not so little project from the beginning. Just wondering what you and the other riggers think about the actual width of your bartacks? -Michael Quote Share this post Link to post Share on other sites
RiggerLee 63 #290 October 23, 2014 Could be a little bit wider but the real danger is in it being too wide, ala swift+. LeeLee lee@velocitysportswear.com www.velocitysportswear.com Quote Share this post Link to post Share on other sites
hackish 8 #291 October 23, 2014 RiggerLeeCould be a little bit wider but the real danger is in it being too wide, ala swift+. Ha, that's exactly why I asked that question. On 1 side a narrow one is guaranteed to catch the line but on the other too narrow is probably not quite as string as a proper dimensioned bartack. -Michael Quote Share this post Link to post Share on other sites
Quagmirian 40 #292 October 28, 2014 I'm slowly cracking on with the sewing [inline rib_small.jpg] Quote Share this post Link to post Share on other sites
DougH 270 #293 November 2, 2014 RiggerLeeCould be a little bit wider but the real danger is in it being too wide, ala swift+. Lee Lee, what is the story there? I still see some swift+ reserve canopies floating around."The restraining order says you're only allowed to touch me in freefall" =P Quote Share this post Link to post Share on other sites
pchapman 280 #294 November 2, 2014 There was a 1994 bulletin to inspect Swift Pluses for too-wide bartacks, as one had been found with ones wide enough to miss the fingertrapped line inside. That was for the line cascades. Other than that the canopies were fine. Although they often had fairly wide bartacks, any actually bad canopies were probably weeded out years ago. (Still, always good to check that some ancient bulletin wasn't overlooked...) Quote Share this post Link to post Share on other sites
gowlerk 2,297 #295 November 2, 2014 DougH***Could be a little bit wider but the real danger is in it being too wide, ala swift+. Lee Lee, what is the story there? I still see some swift+ reserve canopies floating around. If you are inspecting a Swift plus and you checked for SBs, you would find this: http://hq.apf.asn.au/images/e/e5/329A.pdfAlways remember the brave children who died defending your right to bear arms. Freedom is not free. Quote Share this post Link to post Share on other sites
accumack 14 #296 November 2, 2014 DougH***Could be a little bit wider but the real danger is in it being too wide, ala swift+. Lee Lee, what is the story there? I still see some swift+ reserve canopies floating around. There was a recall but I remember it on the Safety flyer not the Swift the bartack was actually too wide we had bartacks without the center straight stitch at the start. Quote Share this post Link to post Share on other sites
Quagmirian 40 #297 November 4, 2014 Yeah, I use two rows of straight stitch followed by a narrow zigzag, which from a strength perspective isn't ideal, but Dacron stretches much less than nylon, especially at a fingertrap, so I can't see it breaking any time soon. Thanks for the idea pchapman, instead of throwing away the old main container, I cut off the reserve and the reserve bottom flap, rebound it and ended up with a basic belly container. It looks quite nice to be honest. And just for future reference, freekflyguy is my Chief instructor and resident test dummy jumper. Before [inline chaser.png] After [inline belly_small.jpg] Quote Share this post Link to post Share on other sites
pchapman 280 #298 November 4, 2014 Cool. Perfect container for that -- with a quite flexible top flap so that flap could be retained, and it even has velcro at the top corners, to hold things closed around the risers. Hey, a Racer's (or Chaser's...) reserve container is derived from a belly mount design, so you're just reversing the process for the main! Quote Share this post Link to post Share on other sites
Quagmirian 40 #299 November 18, 2014 I'm still slowly cracking on with construction. Should be finished and jumped within a few weeks (no promises). [inline end_cell_small.jpg] Quote Share this post Link to post Share on other sites
Quagmirian 40 #300 November 30, 2014 I've finished all the main seams and I'm now working on the line attachments and lines. [inline ab_small.jpg] [inline ust_small.jpg] [inline tail_small.jpg] Quote Share this post Link to post Share on other sites
