nathaniel 0 #1 March 25, 2003 Found this image from a link on usenet... Quote > the classic method (red adair style) is using a lot of water and dynamite, > but is pretty slow. a hungarian team has developed a better and cheaper > method: they mounted two mig(jet)-engines on a t34 chassis and used them to > blow out the fire with a special water/foam mixture. proved to be a very > good method in kuwait. Its inherent fault was that, IIRC, they could only operate both engines together at about 30% thrust. Any attempt to increase the thrust usually resulted in it burning out the brakes and taking off down the road at considerable speed. Its nickname was 'Saddam Husseins Getaway Car' My advice is to do what your parents did; get a job, sir. The bums will always lose. Do you hear me, Lebowski? Quote Share this post Link to post Share on other sites
