Squeak 17 #1 March 28, 2003 Any one know how to by pass the copy control on CDs?You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
AggieDave 6 #2 March 28, 2003 singing... "ohhhhhhhhhh, Copy control, control....ohhhhhhhhhhhhhh Copy control, control..."--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
billvon 3,121 #3 March 28, 2003 >Any one know how to by pass the copy control on CDs? There's copy control on CD's? I can't see how the heck that could work; if the CD will play you can make a copy of it on a PC. Quote Share this post Link to post Share on other sites
AggieDave 6 #4 March 28, 2003 Quoteif the CD will play you can make a copy of it on a PC. Actually, no. Ripping a CD (assuming its audio) uses a different process then playing/reading the CD. A few new CDs have copy-protection that's sometimes a bitch to beat. Squeak, Do a google search about it with the CD title, I'm willing to bet that someone has cracked that version before and will have info.--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
billvon 3,121 #5 March 28, 2003 >Ripping a CD (assuming its audio) uses a different process then > playing/reading the CD. Well yeah, but you can make a .WAV file of any audio source, including a CD. If the CD will play at all you can get its audio. Most rippers support either direct ripping or audio ripping (i.e. playing it as if it was an audio CD, capturing the audio, then creating the .WAV file.) That process also messes with the watermark scheme, where a secret watermark is embedded in the music and read by other CD players to disable/enable play. Quote Share this post Link to post Share on other sites
Jimbo 0 #6 March 28, 2003 Quote A few new CDs have copy-protection that's sometimes a bitch to beat. Explain please. Anyone should be able to do a byte level copy of the CD and burn that image onto another CD. The off the shelf CD ripping software may be too complicated to try something this simple, but rawrite or dd ought to work. Thinking about this, I've never tried to use rawrite or dd to do this, will they work on music CDs? - Jim"Like" - The modern day comma Good bye, my friends. You are missed. Quote Share this post Link to post Share on other sites
lummy 4 #7 March 28, 2003 Hmmm..... Not that I've ever done it, but there's programs that will do a sector for sector copy instead of reading it... supposed to be a mirror image... Bill, some cd vendors will do whacky things like put a file after the last track or mark it as a bad sector or something like that. The app will look for that I THOUGHT Nero did sector copies....I promise not to TP Davis under canopy.. I promise not to TP Davis under canopy.. eat sushi, get smoochieTTK#1 Quote Share this post Link to post Share on other sites
AggieDave 6 #8 March 28, 2003 QuoteThinking about this, I've never tried to use rawrite or dd to do this, will they work on music CDs? That's a good question, I've never tried either, atleast with audio CDs...hmmm.--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
billvon 3,121 #9 March 28, 2003 >Anyone should be able to do a byte level copy of the CD and burn > that image onto another CD. The off the shelf CD ripping software > may be too complicated to try something this simple, but rawrite or > dd ought to work. The problem is that CD players do error correction that you can't turn off, and even a byte level copy will try to either correct the error or give up and flag the sample invalid. An audio player will then do an interpolation and the result won't be that noticeable, but a byte-level copy will write a 0 to the copied disk (or some other erroneous value.) Some copy protection schemes put intentional errors on their disks, so when played back on audio systems you don't notice much - but on the copy you get annoying clicks. You can always do an audio copy, though, which (with good equipment) isn't much different from the original, although it is _slightly_ degraded. I think that's why any copy protection scheme out there is ultimately doomed. Quote Share this post Link to post Share on other sites
Kris 0 #10 March 28, 2003 Then again...he could be talking about a data CD. In which case, there are a slew of different methods in use. False file sizes, encrypted keys hidden in overburn areas, file encryption tied to the master, etc... Usually a bit-bit copy with something like Clone-CD will work, but not always. Two of the more popular encryption schema in use today are StarForce and CrypKey. KrisSky, Muff Bro, Rodriguez Bro, and Bastion of Purity and Innocence!™ Quote Share this post Link to post Share on other sites
Squeak 17 #11 March 28, 2003 thatnks guys but not one bit of that made sense I use adaptec CD burner any advice on if it can copy and Ausdio CD with copy protection???You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
PhreeZone 20 #12 March 28, 2003 Anyone remember the Catus protection scheme they tried a bit ago and ended up having to replace most the CD's they sold?Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
Kris 0 #13 March 28, 2003 You might want to do some research... New Audio Disc Formats and Copyrights Copy Protection On CDs Is 'Worthless' Felten Follower Examines Crippled Music Disks KrisSky, Muff Bro, Rodriguez Bro, and Bastion of Purity and Innocence!™ Quote Share this post Link to post Share on other sites
