polarbear 1 #1 June 13, 2012 Anybody out there have a recent copy of the line trim specs for Tempo reserves? I can't find them on the aerodyne website. "Holy s*** that was f***in' cold!" Quote Share this post Link to post Share on other sites
indyz 1 #2 June 13, 2012 My Tempo manual, which I believe was current when Aerodyne absorbed PISA, doesn't list the trim specs. Quote Share this post Link to post Share on other sites
riggerrob 644 #3 June 13, 2012 Tempo Reserve Line Trim Tempo 120 A to B 65mm B to C 132mm C to D 191mm Deployment Setting 130mm below C full flight setting 350mm above D Tempo 150 A to B 73mm B to C 148mm C to D 214mm Deployment Setting 130mm above A Full flight setting 400mm above D Tempo 170 A to B 80mm B to C 162mm C to D 234mm Deployment setting 130mm below C Full flight setting 380mm above D Tempo 210 A to B 84mm B to C 171mm C to D 247mm Deployment setting 130mm below C Full flight setting 460mm above D Tempo 250 A to B 88mm B to C 178mm C to D 270mm Deployment setting 130mm below C Full flight setting 500mm above D Deployment setting means that the toggle is inserted into the deployment brake loop and is touching the steering guide ring. Full flight setting means that the toggle is touching the steering line guide ring. These dimensions are from a faded, fourth-generation photo-copy. Mind you, I have never had to re-line any of the hundreds of Tempos that I repacked. Only one customer complained are his Tempo turning irrationally, but then his harness was assymetrical by five inches! Hah! Hah! Quote Share this post Link to post Share on other sites
polarbear 1 #4 June 15, 2012 Thanks...I've gotten no response from Aerodyne yet. The trims you gave me match the canopy I'm inspecting, so that's good. "Holy s*** that was f***in' cold!" Quote Share this post Link to post Share on other sites
