JackC1 0 #1 April 18, 2012 Has anyone else had problems with their Cookie G3 visor popping open when head down? Any ideas on how to stop it? Quote Share this post Link to post Share on other sites
Skydivesg 7 #2 April 18, 2012 Go direct to the source. cookie@cookiecomposites.comBe the canopy pilot you want that other guy to be. Quote Share this post Link to post Share on other sites
linestretch 0 #3 April 18, 2012 QuoteHas anyone else had problems with their Cookie G3 visor popping open when head down? Any ideas on how to stop it? Watched a gal in the bigway head down camps have hers pop open. Not all the way...maybe half. Seemed pretty odd for it to open in that orientation...so I know you're not the only one. Sorry, that's all I have.my pics & stuff! Quote Share this post Link to post Share on other sites
padraigbrowne 0 #4 April 18, 2012 Only reason I can think of is air pressure build-up inside helmet from air rushing in rear vent . Could push visor out far enough to pop ? Quote Share this post Link to post Share on other sites
JackC1 0 #5 April 18, 2012 Quote Only reason I can think of is air pressure build-up inside helmet from air rushing in rear vent . Could push visor out far enough to pop ? I was thinking it could be air getting in the top of the visor and pressurising as it happens when you look down between your legs. But the rear vent is smack bang in the airflow at that point. Easy to test, I'll just gaffa tape the vent up. If it cures it, job done. Cheers, I didn't think of that. Quote Share this post Link to post Share on other sites
Squeak 17 #6 April 19, 2012 QuoteOnly reason I can think of is air pressure build-up inside helmet from air rushing in rear vent . Could push visor out far enough to pop ? I would hazard a guess and say the visor was not seated properly when put on.You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
dcfreefly 0 #7 April 23, 2012 How long have you had it? Do you keep the visor open a lot on the ground? There are little o-ring like thingys in the closing mechanism which are what hold the tension to keep the visor closed. They come in different strengths and I've seen different types in both g2's and g3's. They also can wear and lose their strength. I recently had the issue and have replaced mine with the stronger versions and now it's perfect. Shoot cookie an email and ask them to send you some repacements. Quote Share this post Link to post Share on other sites
