cooperf1 0 #1 March 28, 2012 I've had an issue with my 132k6 for a while. The needle thread gets jammed between the hook and the "position bracket". This doesn't happen on every cycle, and sometimes it will sew fine for a while. The result is needle thread loops hanging from the bottom of the material (at any needle thread tension). So i was curious if anyone has run into this as well: (jammed.jpg, tight.jpg) My knee jerk reaction is to just take the position bracket and/or hook to the mill/grinder: (modify.jpg) The timing looks pretty good, but maybe the hook is a little close to the needle? When the hook tip is at 12 o'clock, it is pretty close to the middle of the scarf, but as it continues to rotate and the needle goes up farther the gap is reduced to about nothing, perhaps even light contact aft of the hook tip. So maybe a better solution would be to move the bobbin/hook assembly farther from the needle? I am unable to find a user manual for timing info (only a parts manual) and i have come to the conclusion one doesn't exist. Any suggestions? Quote Share this post Link to post Share on other sites
councilman24 37 #2 March 28, 2012 See if this one is close enough to help. http://parts.singerco.com/IPinstManuals/132B26.pdf It has timing information. You should need to modify the factory part. Especially that much! I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
cooperf1 0 #3 March 28, 2012 I actually have that manual in paper form, but didn't pay much attention to it since the B26 is a double needle drop feed, and the K6 is a single needle walking foot. But now that i think about it there's no reason the timing would be any different between the two. Thanks for the tip. Quote Share this post Link to post Share on other sites
masterrigger1 2 #4 March 28, 2012 Quote My knee jerk reaction is to just take the position bracket and/or hook to the mill/grinder: (modify.jpg) I would resist that knee jerk reaction! First put a new needle in the machine and check the hook to needle clearance. If you can, use the maximum distance betwen the two before it starts skipping stitches. The real problem is that someone has ground the hook point away to make a new smooth point. This is a standard procedure in lieu of buying a new hook BTW.... By grinding away the point the hook base has to be moved closer to the positioning finger, which as you see by now, can be a bad thing. I would not grind down the positioning finger to fix a bad hook problem. Buy a new hook and I think your problems will go away! Cheers, MELSkyworks Parachute Service, LLC www.Skyworksparachuteservice.com Quote Share this post Link to post Share on other sites
cooperf1 0 #5 March 28, 2012 Mel, thanks for the reply. If the timing is good, i was thinking of grinding more relief on the hook. i wasn't going to touch the tip, just remove some material near where the thread jams (aft of the tip). Quote Share this post Link to post Share on other sites
masterrigger1 2 #6 March 28, 2012 Quote thanks for the reply. If the timing is good, i was thinking of grinding more relief on the hook. i wasn't going to touch the tip, just remove some material near where the thread jams (aft of the tip). It will still bind on the case more than likely. Either move the hook base away from the needle a little or simply buy a new hook. When you start grinding stuff, it usually is a just bad thing! MELSkyworks Parachute Service, LLC www.Skyworksparachuteservice.com Quote Share this post Link to post Share on other sites
theonlyski 8 #7 March 29, 2012 Quote When you start grinding stuff, it usually is a just bad thing! Speaking of which, when should I bug you about that info for setting the 143w2 up to accept 135x17 needles? "I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
masterrigger1 2 #8 March 29, 2012 Try me on Tuesday ..... I should be home by then! MELSkyworks Parachute Service, LLC www.Skyworksparachuteservice.com Quote Share this post Link to post Share on other sites
cooperf1 0 #9 April 10, 2012 I advanced the hook timing. I would guess about 20 degrees. It hasn't jammed since so i think that was the problem. Thanks for the info. It seems to be sewing well now with the exception that the thread and/or bobbin tension(s) vary based on the locations of the loops. Without changing anything, and sewing on the same thickness material, sometimes it appears the thread tension is too high / bobbin tension too low and sometimes vice versa. It seems to randomly vary back and forth and everything in between (sometimes the tensions look balanced). Maybe i'm just being picky. Quote Share this post Link to post Share on other sites
