J-Rock 0 #1 February 21, 2012 I just acquired a Northern Lite container DOM 10/85 made by Paraphenalia. Does anyone out there have a manual or know where I can find one? Im gonna need a bigger hammer.... Quote Share this post Link to post Share on other sites
IanHarrop 43 #2 February 21, 2012 I found this, probably not what you are looking for but... http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=2909030 and this http://books.google.ca/books?id=2PopFBjLZV8C&pg=PA169&lpg=PA169&dq=Northern+lite+manual&source=bl&ots=ldo_D6wX7Z&sig=P0Yd208e1L8iz5PiEh7Hc20SuO8&hl=en&sa=X&ei=wTBDT7D1GuGXiQKxtIyQAQ&ved=0CGUQ6AEwCQ#v=onepage&q=Northern%20lite%20manual&f=false"Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy Quote Share this post Link to post Share on other sites
jonathan.newman 1 #3 February 21, 2012 Check out http://www.velocityrigs.com/support.php?link=ownersManual Quote Share this post Link to post Share on other sites
J-Rock 0 #4 February 21, 2012 This is a standard Northern Lite, I think its the very first model and has a 6 flap reserve system where the PC is packed between the first two flaps so the closing loops do not go through the free bag like they do on the Northern Lite III. Im assuming the manual would be from Paraphernalia not Northern Lite. Thanks for the leads though. Im gonna need a bigger hammer.... Quote Share this post Link to post Share on other sites
pchapman 280 #5 February 21, 2012 Hey, I just realized I have the scanned manual for a Northern Lite, 'sport piggyback', from Para-Phernalia. But even that manual shows the two reserve loops going through the freebag, side to side. It is an early manual as it is mainly about rounds, with added Supplemental instructions for Swift reserves etc. Even for rounds, the pullup cords are shown coming from a double ended closing loop at the bottom of the pack tray. So you're saying you have something even earlier? I'll upload it to parachutemanuals.com in case anyone needs it. Quote Share this post Link to post Share on other sites
PhreeZone 20 #6 February 21, 2012 The upload is approved and anyone wanting it can download it.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
riggerrob 644 #7 February 22, 2012 It is easy to distinguish between Northern Lite I and Northern Lite III because the 'I has rounded corners on the reserve pin cover, while the 'III has square corners on its reserve pin cover. Early Northern Lites should be packed like Strong Dual Hawk Tandem, with only short closing loops attached to the first flap (kicker plate). If you are really good at PRO-packing, you can pack a Northern Lite III with the "ears" (of the reserve canopy) passing outboard of the through-loops. For bulk distribution, it helps if the "ears" are long enough to overlap across the top of the reserve container. Quote Share this post Link to post Share on other sites
J-Rock 0 #8 February 22, 2012 Rob, from your description that is exactly what I have. The freebag has no holes or grommets in the freebag. The first flap or "kicker flap" also has a shock cord loop that goes through the next flap which has three gommets... Ill look at the manual on Phree's site and see if its similar. Im gonna need a bigger hammer.... Quote Share this post Link to post Share on other sites
