Casch
Help - Auto Techies Please!
Add 4 qts and start the motor. Let it run briefly then recheck. Continue to fill until it reads full on the dip stick. I would guess the capacity is 4.5-5qts in a 5.0L V-8. It can also be found in the owners manual.
Here's to the Breezes that blows through the Trezzez.....
I think its 5 quarts. Is this the oil pan with two oil drain plugs in it??? One in the front of the pan, and one in the back??? If it is, many people only pull one drain bolt out, and leave lots of oil still in the pan. Then they fill with 5 quarts, and its way too full!! My books are at work, so I can't get the exact figure. but i am pretty sure that is it!!
5 qts for a 5000cc engine? Not enough oil. My 1.8L engine takes 4.2 quarts of oil.
I've been searching, but I'm coming up short. Start with 6 quarts and be ready for 8 or 9.
So I try and I scream and I beg and I sigh
Just to prove I'm alive, and it's alright
'Cause tonight there's a way I'll make light of my treacherous life
Make light!
Friend of a friend. Worked at a dealer. New kid was changing the oil on a car and asked one of the techs if this was enough. The kid proceeded to open the oil fill on the valve cover and the engine was FULL of oil. The entire engine. He was fired on the spot. I know of engines that size that take under 5 quarts, but some cadillacs take 9 or 10. On that mustang I'm almost sure it is 5 though. Broncos with 5 litres take 6 and a lot of ford vans take 7.
edit to add: My 1.8 takes 4.2 also but you cant go by that. I dont know of any car produced in the last 40 years (save the vw bug) that takes under 4 quarts of oil.
Johnny
--"This ain't no book club, we're all gonna die!"
Mike Rome
OMG!!!! You have NO Fuggin' idea how much grief and $$$$ you just saved me! I only drained the front end of the pan and got barely a quart out of it. I was like CRIMINY! I've been driving around with a quart and a half of oil in my engine! And I poured in 4 quarts and thought I was done. If you hadn't posted about there being two drain plugs...I could have blown the engine or some shit...
If we ever meet, I owe you a case!
[B] THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU!
Oh by the way my dad says "Thank you! And this is why I drive a CHEVY!"
Found specs for an 86 4.6L V8 with oil capacity at 6 qts.
Here's the link (though not very useful for Casch's 84 'stang):
http://www.mustangworld.com/ourpics/fcar/fluids.htm
An 03 Cobra takes 6 quarts...hmm...
I'll keep looking...
Make light!
Would you like to guess how I know the answer to that question!!!!! Same car, 15 or more years ago, same problem (except i left the front plug in, since real cars only have ONE plug in them). Heck,i finally had to raise the whole car up before I actually looked at the oil pan and saw that. GEEZZZ, and people wonder why i prefer to work on corvettes!! :S:S And watch out what you offer on the beer, i might take you up on it, if you happen to be at Eloy at Xmas time!!!;) I'm glad I could help:)
If you're gonna be at Eloy for the Christmas Boogie, you'll get your case. Well, you'll get the money anyway since I'll only be 19. I don't mind spending the cash on a case for ya when I could have spent a lot more money. I had like, 8 quarts in the engine when it only needs 5....yikes. What's yer brand and it'll be there for ya B|
to my knowledge the 4.6L v-8 was not offered in 1984 or 1986.... my 5.0 took 5 quarts and used about a quart every 2000 miles. typical of the 5.0 engine
It's already done, and I like doing the stuff myself personally.
Alright, new oil/filter, fuel filter, fan belt, plugs, distributer cap, PCV valve (like that makes much of a difference). I'm getting ready to take this bad puppy for a backroad drive...mmmm horsepower B|
actually the PCV valve does make a difference. they should be changed (along with the fuel filter)
My fat-finger... '96 4.6L Mustang... that's what I found. Never did find what I was looking for.
Make light!
MMM, Runs suweeeet! The contacts on the distributer cap were sooo corroded, along with the spark plugs that have been in there for 50K miles. Nice new slippery slimy oil, new pcv valve...or is it pvc? Will put a new belt, fuel filter and distributer cap on tomorrow B|...gotta adjust the timing too...it keeps having fits where it feels like it's missing, although that could be the shitty gas and filter too. We'll soon find out ;)
PCV = positive crankcase ventilation.
I gotta change my oil in the Ram this weekend - 13+ quarts. Started buying oil in 5 gallon buckets when I bought that thing. :S
----------------=8^)----------------------
"I think that was the wrong tennis court."
