e.a.hernandez 0 #1 January 16, 2012 Hi, When doing the recommended once a month cut-away cable cleaning what type of lubrication is it recommended? Is PAM oil ok...??? Is it ok just to wipe it with a piece of cloth without doing any lubrication?? Thanks, Erick Quote Share this post Link to post Share on other sites
LDiCosimo 0 #2 January 16, 2012 Search results "cutaway cable cleaning" http://www.dropzone.com/cgi-bin/forum/gforum.cgi?do=search_results&search_forum=all&search_string=cutaway%20cable%20cleaning&sb=score&mh=25 Many recomend Food Grade Silicon. Ace seems to be a popular brand. Oil based lubes will attract and hold onto dirt, so maybe no PAM. Page 85 http://www.unitedparachutetechnologies.com/PDF/Support/Manual/MAN_004___Vector_3_Manual_07_44_13[1].pdf Quote Share this post Link to post Share on other sites
popsjumper 2 #3 January 16, 2012 QuoteMany recomend Food Grade Silicon. Ace seems to be a popular brand. Oil based lubes will attract and hold onto dirt, so maybe definitely no PAM. The best, IMO. If you go to Deland, Check with Chutingstar Rigging...J or Miki or Nathan should be able to either sell you some or tell where to get it nearby.My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites LDiCosimo 0 #4 January 16, 2012 There ya go. Thanks for the touch up pops Quote Share this post Link to post Share on other sites Gary73 10 #5 January 16, 2012 I've been using Du Pont Teflon Multi-Use for years with very good results. Spray it on a rag, wipe down the cables (cutaway or reserve), and slide the cables back in. It goes on wet, then dries quickly to a very low-friction, non-sticky finish. "Extraordinary claims require extraordinary evidence." - Carl Sagan Quote Share this post Link to post Share on other sites councilman24 37 #6 January 16, 2012 If the local ACE store doesn't carry it they can order the food grade silicon. It doesn't contain any petroleum distillates CRC Industrial Food Grade Silicone. No. 03040 Green 10 oz can will last a long time. A little on a paper towel or rag will do both cables.I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
