Michele
SPIES!
I don't know for sure...But I seem to have spyware or something like that on my machine. Out of nowhere, when it has not happened before, I am getting these pop-up windows that are advertising several different things...
I don't know how to scan for it, and I don't know what *free* nuke'm stuff is available. Any hints?
Ciels-
Michele
~Do Angels keep the dreams we seek
While our hearts lie bleeding?~
Definitely hit that Lavasoft link and download the free copy of Ad-Aware Personal Edition. It will remove the spyware from your PC.
Sky, Muff Bro, Rodriguez Bro, and
Bastion of Purity and Innocence!™
install ad aware and "spybot - search and destroy". Between the two they should get everything. Run them both regularly (once every couple weeks) updating them when releases come out.
let my inspiration flow,
in token rhyme suggesting rhythm...
Thanks, everyone...
'Kay, after trying to figure out this hi-tek computer stuff, I managed to get the download started....I'll let you all know what I find (and no, Clay, I don't surf porn...).
Also, does anyone know of a good virus scanner?
I've been getting slower and slower page loads, and cleaning cookies just don't seem to help like they used to. Did a defrag, but also want to check and see that.
Ciels-
Michele
Well, fuck me.
I can't do this. My computer is refusing to give me something I can use...
"MZ?   ÿÿ ¸ @ Ð º ´ Í!¸LÍ!This program cannot be run in DOS mode.
$ m°dü)Ñ
¯)Ñ
¯)Ñ
¯)Ñ
¯(Ñ
¯)Ñ ¯oÑ
¯Kί Ñ
¯vó ¯+Ñ
¯î× ¯(Ñ
¯Öñ¯(Ñ
¯Rich)Ñ
¯ PE L ?lØ; à   "  ¯!  @ @      p        G i (A d ` @ @ ( .text &!  "  `.rdata y @  & @ @.data x P  . @ À.rsrc @ `  2 @ @ V?5?@@ Wh  jÿÖ?=È@@ P£4T@ ÿ×h@? j£0T@ ÿÖP£lT@ ÿ×h  j£\T@ ÿÖP£LT@ ÿ×£8T@ ? jX_^j?ÈZöÁt
Ñé?ñ ?¸íëÑéJuì?8T@ ? ?@=  |ÖÃV?5?@@ Wÿ54T@ ÿÖÿ54T@ ?=?@@ ÿ×ÿ5lT@ ÿÖÿ5lT@ ÿ×ÿ5LT@ ÿÖÿ5LT@ ÿ×_^ÃU?ìQQ¡pT@ V?Eü¡`T@ ?Eø?EøP?EüPjè8 ?Eü?M?à??EøP?EüPjèj ?EøP?EüPjè ?uü?EøP?EüPj?æèF ?".....
That's what comes up. page after page after page...
And I can't open "shell" or whatever it wants to get it. And I don't have a clue as to what DOS mode is. And it isn't working.
Will someone please come over and do this for me????????
(And yes, I am like this with my car, too.)
ARGGGGGGGGGGGHHHHHHHHHHHHH!
Just execute the program and follow the prompts.
I tried.
It told me "NO. Go find something to open it with."
So I tried. And then it said, "you stupid chick. No Program for you!! Gibberish!".
Sigh.
Ciels-
Michele
Your computer doesn't recognize executable files? I've never seen that. Did you lose the .EXE extension or something? Your using a recent version of Windows (98/2k/XP)?
Edited: Just to make sure we are on the right page, you got the following executable right? It should be called AAW6.EXE. If not, get it from http://www.pcworld.com/downloads/file_download/0,fid,7423,fileidx,1,00.asp
$ m°dü)Ñ
¯)Ñ
¯)Ñ
¯)Ñ
¯(Ñ
¯)Ñ ¯oÑ
¯Kί Ñ
¯vó ¯+Ñ
¯î× ¯(Ñ
¯Öñ¯(Ñ
¯Rich)Ñ
You mean this isn't normal? Damn, I'm dumber than I thought.:S
Chris
Chris
Just click on it, right?
If it has an EXE extension, Windows will recognize it as an executable. Double clicking on it will execute the program. Or you can right click it once to bring up some choices, such as executing it ("Open"), or checking its properties.
edited: You can look at the properties of the file you got and make sure it says "Application" under "Type of File". Make sure the file name also ends in .EXE, although that should be the case unless you accidently renamed it to some other type of file.
hmm, another computer dummy here(no offense Michele), I downloaded and ran it, had a bunch of stuff come up and it stops halfway through the scan. Just freezes up,(too much porn?:$) had to shut the computer off to get rid of the screen aahhggg
Norton Virus protection here
dropdeded
The Dude Abides.
Run the program by going through the Start menu. Start -> Programs -> Lavasoft Ad-Aware 6 -> Ad-Aware 6.
Then when the program opens go to "Check for Updates Now." Let it install the the newest update it finds, and go back to the main program screen. Then click "Start." The default options should be good. Then just let it run. This may take a few minutes. When its done, just go through all the prompts saying Yes or Next. You will get to a screen that has the results of the scan. You can see what it thinks is bad. I think Ad-Aware is pretty good at leaving legitimate programs alone, so you can almost ignore what it says. Just let it quarantine the files it found. If your computer doesn't break from what this program removed (it shouldn't) you can delete the quarantined files later (should be an option to see quarantined archives from the main screen).
