JerryBaumchen 1,484
QuoteI have no way to test the strength of a harness. Neither does anyone else as far as I know.
PD does have a drop test tower that could be used to test a harness.
And that was an excellent writeup with some good thoughts.
JerryBaumchen
PS) Your hot cutter will got out in a day or so; IMO that thing is way too heavy for production use. It weighs 2 lbs compared to 2 oz for my HK-60.
http://www.hsgmusa.com/Products/hsg-0-heat-cutter.asp
http://products.mmnewman.com/item/heavy-duty-hot-knife-and-tips/heavy-duty-hot-knife/hk-60?
councilman24 37
PD does have a tower. But I don't. The comment referred to a field test similar to TS-108.
Besides, how long would we argue about the force to use to test a harness without damaging it. Some think TS-108 damages canopy fabric unacceptably. And canopy fabric is an individual component, not an assembly with stitches and various loading methods.
From another thread I wondered about your webbing junction pull testing. Did you do that or have it done? If you had it done I'm curious about the cost. I've always wanted to be able to pull test to 10000lbs. Not only for skydiving but for climbing/rescue.
Your hot knife works as well as mine? If so I may have to get one of them. The others I have don't cut as well. And I like being able to turn it on with the trigger and be ready in 10 sec. Mine would build up your forearm also.
At least you got to try it.
No great rush to get it back.
Terry Urban
D-8631
FAA DPRE
Trae 1
On my reserve there is a small stain on the F111 .
My rigger does a thumb test on every repack.
It looks like he's trying to push his thumb through the fabric.
I'm wondering if the F111 will eventually be destroyed by his testing it all the time.
It has passed so far but is his (somewhatbrutal) testing making it weaker each time?
riggerrob 644
riggerrob 644
I have only ever seen one PD reserve damaged during a proper pull test, circa 1999. I suspect that the new FAA Senior Rigger had done a second pull-test exactly on top of an older pull-test, because the previous rigger was too lazy to mark his work.
Pull-testing once IAW PIA standard usually leaves minor weave separations. No big deal, as long as mark the test are to discourage other riggers from repeatedly pull-testing the exact same are.
I consider it a big deal!
But you have to remember that I am probably the only rigger on this website that is also certified in methods of non-destructive testing.
You might want to ask PD how many reserves have had panels split after a reserve deployment that started in the area of a pull test.....
I know of two.
The next question is how many reserves (barring Phantoms) have actually failed from weak fabric during a deployment?
I do not know of any!
TS-108 is label a non-destructive test when in actuallity is a destructive test....Google is your friend here.
Anytime the positive result is failure or destruction, it is considered a destructive test.
Terry hit the nail on the head about one thing. If you suspect fabric to be "different", you need to test it.
But here is what I do differently:
I install a 8"x8" patch over the area of interest. I then use the removed material and pull test that.
The difference is that if it fails and is a positive test result; i just patched a bad canopy. No big deal.
If the test is negative and the material is considered good, I did not possibly damage a otherwise perfectly good canopy!
MEL
www.Skyworksparachuteservice.com
pchapman 280
You're getting at the issue of a "non-destructive test" in a general sense, and "Non-Destructive Test (NDT)" in a technical engineering sense.
So we can have different levels of testing:
1) tests that are non-destructive, even to items that are tested "bad" (weak, damaged, out of spec, whatever). (e.g., the ultrasound, magnetic particles, x-ray, or whatever doesn't cause damage in any case). You're making the point that that's true NDT.
But there's also:
2) tests that are non-destructive when the parts are OK. So you can do a 100% sample and not destroy every item that comes off the production line. However, for a bad part, one either:
2a) destroys the whole item (e.g, the cable failed the tensile test, it broke)
or
2b) destroys only the section of the item being tested. So it isn't destructive to the whole item, just the section being tested, so that one can theoretically save the production item by fixing the section that failed. (e.g., ripped canopy panel, or other localized damage to the tested item)
I'm not sure we can use the term "destructive testing" either. I may be wrong, but that is normally defined as testing something to its breaking point. For us, that would be ripping every spot on a canopy we test, and recording the breaking strength.
So we need terminology for something in between.
Then we can better argue about whether TS-108 is a Locally-Non-Destructive-To-Good-Items-But-Locally-Destructive-To-Failed-Items-Test.
(Note: I have no certifications in any of NDT, DT, or LNDTGIBLDTFIT.)
P.S. That's interesting about actually seeing reserves fail at pull test locations.
Whoah.
But there's also:
or
Peter,
It is pretty simple. TS-108 is tesing for destruction.
That is the positive result of that test.Period.
The part that most do not understand is terms like "elastic", "plastic" and "yield".
A non-destructive test does not alter the material in ANY manner.
In the case of TS-108, weave separation is an alteration of that material
To take it further, I believe that some fabric will enter into the plastic stage even at 30 lbs of test strength. But it it may not enter the yield stage of destruction at that point and time, just to the edge of it......
Cheers,
MEL
The pull test is also a Destructive Test rather than the claimed Non-Destructive test by PIA.
This is one correction that we are putting in the new rigger handbook BTW.
Also, if you conduct or perform a pull test on certain canopies in the field, that test will void the TSO on that canopy.
Cheers,
MEL
