turtlespeed
Pilots vs. Maintenance Crew
I was e-mailed this from a co-worker
Enjoy!
> Subject: Pilots and mechanics
> After every flight, pilots fill out a form called a gripe sheet, which
> conveys to the mechanics problems encountered with the aircraft during the
flight that need repair or correction. The mechanics read and correct the
problem, and then respond in writing on the lower half of the form what
remedial action was taken, and the pilot reviews the gripe sheets before the
next flight.
> Never let it be said that ground crews and engineers lack a sense of
humor. Here are some actual logged maintenance complaints and problems as
submitted by Qantas pilots and the solution recorded by maintenance
engineers.
> By the way, Qantas is the only major airline that has never had an
> accident.
> (P = The problem logged by the pilot.)
> (S = The solution and action taken by the mechanics.)
> P: Left inside main tire almost needs replacement.
> S: Almost replaced left inside main tire.
> P: Test flight OK, except auto-land very rough.
> S: Auto-land not installed on this aircraft.
> P: Something loose in cockpit.
> S: Something tightened in cockpit.
> P: Dead bugs on windshield.
> S: Live bugs on back-order.
> P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
> S: Cannot reproduce problem on ground.
> P: Evidence of leak on right main landing gear.
> S: Evidence removed.
> P: DME volume unbelievably loud.
> S: DME volume set to more believable level.
> P: Friction locks cause throttle levers to stick.
> S: That's what they're there for.
> P: IFF inoperative.
> S: IFF always inoperative in OFF mode.
> P: Suspected crack in windshield.
> S: Suspect you're right.
> P: Number 3 engine missing.
> S: Engine found on right wing after brief search.
> P: Aircraft handles funny.
> S: Aircraft warned to straighten up, fly right, and be serious.
> P: Target radar hums.
> S: Reprogrammed target radar with lyrics.
> P: Mouse in cockpit.
> S: Cat installed.
> P: Noise coming from under instrument panel. Sounds like a midget pounding
on something with a hammer.
> S: Took hammer away from midget.
I'm not usually into the whole 3-way thing, but you got me a little excited with that. - Skymama
BTR #1 / OTB^5 Official #2 / Hellfish #408 / VSCR #108/Tortuga/Orfun
Some of the squawks and responces on this particular list I've seen on lists and comics dating back to WWII.
It's fun to watch these things evolve over the course of time.
Just a heads up, it's -almost- time to start the annual "gonna lose one on takeoff" Santa joke pool to see the first occurance this year of that chestnut.
quade -
Well, first we have the puking pumpkin and the tanning turkey.
Wendy W.
Even More of these:
Defect: The autopilot doesn't.
Action: IT DOES NOW.
Defect: Seat cushion in 13F smells rotten.
Action: Fresh seat cushion on order.
Defect: Turn & slip indicator ball stuck in center during turns.
Action: Congratulations. You just made your first coordinated turn!
Defect: Whining sound heard on engine shutdown.
Action: Pilot removed from aircraft.
Defect: Pilot's clock inoperative.
Action: Wound clock.
Defect: Autopilot tends to drop a wing when fuel imbalance reaches 500 pounds.
Action: Flight manual limits maximum fuel imbalance to 300 pounds.
Defect: #2 ADF needle runs wild.
Action: Caught and tamed #2 ADF needle.
Defect: Unfamiliar noise coming from #2 engine.
Action: Engine run for four hours. Noise now familiar.
Defect: Noise coming from #2 engine. Sounds like man with little hammer.
Action: Took little hammer away from man in #2 engine.
Defect: Whining noise coming from #2 engine compartment.
Action: Returned little hammer to man in #2 engine.
Defect: Flight attendant cold at altitude.
Action: Ground checks OK.
Defect: 3 roaches in cabin.
Action: 1 roach killed, 1 wounded, 1 got away.
Defect: Weather radar went ape!
Action: Opened radar, let out ape, cleaned up mess!
