turtlespeed
Little help here...
I have been searching for something that
will let me know the correct size of PVC that I can use
to intall propane throughout a house, or even if you
can use PVC w/ Propane.[:/]
Cant seem to find any though.
Thanks in advance.
I'm not usually into the whole 3-way thing, but you got me a little excited with that. - Skymama
BTR #1 / OTB^5 Official #2 / Hellfish #408 / VSCR #108/Tortuga/Orfun
More specifically, the thicker natural gas "plastic" pipe used for underground gas lines....I need to know if you can use that for LP. I think that you can, but I need documentation to back this up.
Well, knowing that PVC can't be used in pressurized air situations, since it is porus in terms of gas, then I'd probably say no to the propane.
hmmm...dunno about that. Direct experimentation has shown that PVC and propane make one hell of a potato gun. We actually shot a barbequed chicken across the river.....
everybody sing along "What was I thinking...."
Jump
Scars remind us that the past is real
I wouldnt realy rely on a bucnh of bored skydivers giving you advice on something that can cuase a nice flame:ph34r:
I would probably use copper but the thing is you have to be sure to have all the gas off and not to ignite the torch until youve ventilated your crawlspace/basement/area that youll be fitting the pipes:ph34r:
My photos
My Videos
This is for new construction. We are building a "House" in south Texas.
There is no gas service there, and we are installing a LP system. I was just looking for
documentation that qualifies the heavy polyethelene pipe used for Natural gas
underground for use with propane.
But you are right about that skydiver/flame thing...
Heh, well, if it were that simple...
i have called and talked to retailers, manufacturer's reps, distributors, plumbers, and even the code enforcement of this area. I'm still not getting any "Clear" response to my request. All I want is to knbow where to get the literature, so I can get it.
Hmm, never thought to call Hank...
Im sure that you probably could... but I dont think that I would want to. You should probably look for a flexible copper line, you can buy it in coils of different sizes and is usually relitively easy to work with.
You can even find a way so "sweat" or solder the fittings together, its not terribly difficult and easier than messing w/ pvc. Plus you can check w/ a small air compressor and a guage to confirm that there are no leaks....
at least thats what Im thinkin.... :S
Goddam dirty hippies piss me off! ~GFD
"What do I get for closing your rig?" ~ me
"Anything you want." ~ female skydiver
Mohoso Rodriguez #865
hes right.... cuz now that I think about it even my cheaply built house, has black iron once you get to the house. its only copper from the tank (yes LP) to the house cuz iron wont hold up under ground. (i think)
Ok. But the gas company uses a yellow plastic pipe, polyethelene to run the gas main.
I am running the line about 250 yards, that is a lot of copper. So, we are opting for the gas company solution. I just need to find something that gives me a seal of approval of some kind. I also need to know what the max pressure that is allowed is. So we can set our regulators for it.
are you going to have service from a "line" or a tank? b/c if its a tank, the tank should come regulated when you order it. at least thats how it works here. I couldnt afford to buy one so I lease it. which give me the chance to negotiate w/ different companies each year when my lease comes up, and I always have a well maintained and good looking tank.
We are going to purchase the three tanks...this isn't a small house we are building...12000 square feet, plus the kitchen is going to be able to support restraunt style cooking. It's like a hunting lodge...
