gweeks 1 #1 July 19, 2011 I want to get some clear plastic sheeting similar to what is used to make the pouch/window in a rig for the AAD control unit. Can someone tell me what that's called and where to find it? Thanks! Quote Share this post Link to post Share on other sites
indyz 1 #2 July 19, 2011 JoAnn Fabrics carries a few different weights of clear plastic that would probably work. It's on the same rack as the heavy-duty fabrics and ripstop. Quote Share this post Link to post Share on other sites
peek 21 #3 July 19, 2011 QuoteI want to get some clear plastic sheeting similar to what is used to make the pouch/window in a rig for the AAD control unit. Can someone tell me what that's called and where to find it? I got some once at a place that does replacement convertible (car) tops. It is what they use for the rear window. I got a small piece of scrap for zero cost. Quote Share this post Link to post Share on other sites
jackwallace 3 #4 July 20, 2011 Also try a boat place. They use a heavy grade of the stuff.U only make 2 jumps: the first one for some weird reason and the last one that you lived through. The rest are just filler. scr 316 Quote Share this post Link to post Share on other sites
