mx19 0 #1 June 9, 2011 Just a quick question. I'm after a little bit of help pricing a pd143r Dom 92 I think and I'm pretty sure that there is 20-25 repacks and 3/4 jumps, will double check numbers etc tomorrow but if you can help that would be great. Cheers Quote Share this post Link to post Share on other sites
theonlyski 8 #2 June 9, 2011 QuoteJust a quick question. I'm after a little bit of help pricing a pd143r Dom 92 I think and I'm pretty sure that there is 20-25 repacks and 3/4 jumps, will double check numbers etc tomorrow but if you can help that would be great. Cheers I wouldn't give much more than a few hundred dollars for it, and that's only once it's been checked out by PD."I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
likestojump 3 #3 June 9, 2011 QuoteJust a quick question. I'm after a little bit of help pricing a pd143r Dom 92 I think and I'm pretty sure that there is 20-25 repacks and 3/4 jumps, will double check numbers etc tomorrow but if you can help that would be great. Cheers get rid of "i think" and of the "pretty sure" and give some hard FACTS, and then you can get a reasonable estimate. Otherwise you will be getting an wild ass guess :( Quote Share this post Link to post Share on other sites
mx19 0 #4 June 10, 2011 That's fair enough mate. Here are the facts:- d.o.m.- jun 93 and it has 15 routine repacks and 3 repacks after rides if you could help that would be great. Cheers Quote Share this post Link to post Share on other sites
GravityGirl 0 #5 June 10, 2011 Pull test and $300 top end. ~~~~~~~~~~~~~~~~~ Peace and Blue Skies! Bonnie ==>Gravity Gear! Quote Share this post Link to post Share on other sites
gowlerk 2,277 #6 June 10, 2011 That particular size is in high demand and short supply. I'm guessing that with a passed pull test, which should not be a problem, someone would snap it up for at least $450. Of course, if it can't pass the pull test, it is only a car cover. There are almost none available used. KenAlways remember the brave children who died defending your right to bear arms. Freedom is not free. Quote Share this post Link to post Share on other sites
