Sebazz1
Tis better to be on the ground...
Sebazzzz. dont be foolish... did you at least check the spot?
I remember when a certain dzcommer was in charge of checking the spot a few years ago. It was a DC3 load and we were the last group out. After landing 8 miles off the DZ, all he had to say was that he couldn't tell if the spot was good because of the cloud cover. :)
Edited cause i wanted to, so there!!
___________________________________________
meow
I get a Mike hug! I get a Mike hug!
naw that was before that...
but see when it gets really really really cold you should avoid sticking your head out the door unless you are exiting... hence why i wont stick my head all the way out the door when spotting on really really really cold days:ph34r:
If you have over 100 jumps and you exit a plane from 15,000 feet with the purpose of doing a four way RW jump or smaller you should be able to achieve a minimum of 6 points or don't bother pulling
The sole reason I freefly ;)
I promise not to TP Davis under canopy.. I promise not to TP Davis under canopy.. eat sushi, get smoochieTTK#1
