bodypilot90 0 #1 November 11, 2003 Sun creams This is becoming a subject of more and more debate. There are doctors and researchers who are beginning to think that sun creams could be harmful because they encourage people to stay out in the sunshine for longer.They think that the protection the creams give you against burning may not actually stop you increasing your risk of malignant melanoma. The only way to be absolutely sure of reducing your melanoma risk is to keep out of the sun. And if you must get a tan, do it very gradually so that you don't damage your skin. Having said all that, using a sun cream is better than getting burnt so here is what is currently known about them. What to buy Cheap suncreams are just as good as expensive ones. They are all tested the same way and it is the SPF that matters most. Do check the 'use by' date. Most creams will last about 2 or 3 years - so it is OK to use last year's, but not a bottle from 5 years ago! Sun creams have changed a lot in the past 15 years. There is a huge range and it can be difficult to know what to buy. You should choose one that says it protects against both UVA and UVB radiation from the sun. This may be labelled 'broad spectrum'. Then you need to choose the right sun protection factor. We recommend at least factor 15. This is because it gives the best balance between protection and cost. The higher factor creams are more expensive, but do not give much more protection than factor 15. If you use Factor 15, only 7% of the harmful rays will get through Factor 30, only 4% of the harmful rays will get through Factor 60, only 2% of the harmful rays will get throughSoyou can see, you are getting some more protection with the mostexpensive creams, but not that much more. There is no suncream thatcan give you total protection. 98% protection (with factor 60) isabout the best you will get. Don't assume that because you have put on suncream, you can stay out without burning. Keep an eye on your skin (and your children's skin) atall times. Children have thinner, more delicate skins than adults and are at higher risk of burning. It is best to use waterproof suncream because it will wear off more slowly. Quote Share this post Link to post Share on other sites
