spencer
Spectre V Storm
In a nut shell what differences would I notice in flying the storm to a Spectre both same size canopys 135s as i have done over a 1000 on a spectre. Id like to stick with the 7 cells.
Thanks.
The Storm sounds like it might be nice, but the snappy opening bothers me. I love the soft snivel openings I get with my Spectre and I find the flare sufficient.
You live more in the few minutes of skydiving than many people live in their lifetime
Thanks.
1Kplus jumps on Storms...."Snappy openings?"
I don't have em'.
Thanks.
I don't have em'.
I would compare the Storm's openings to a Katana opening, but with much better heading control. That different looking "high speed snivel" that just open smooth. For the flight characteristics, the easiest comparison would be that the Storm is like a 7-cell Sabre2. It has the ability to have an incredible range. I jumped one right when they first came out and thought "wow, this canopy is going to be really popular..."
Thanks.
My Storm averages 600-700 foot terminal freefall openings, and I pull out the center cell and spread it nice and wide, and push the slider to the back to expose the nose, in an attempt to get quicker openings. I also have a smaller-than-stock slider on it. I don't think snappy openings are a problem with this canopy. On wingsuit jumps I routinely get a stuck slider.
Brian
Interesting! This is also a problem I don't see. I'm loading my Storm 150 at 1.5, no hard openings, no stuck sliders. Takes approx 500' to open.
A lot of jumps on Spectre's too; Dave hit the description nicely. It opens smoothly and usually on heading, it's a sporty fly at my wingloading.
I push the nose in, quarter the slider, and slightly roll the tail. Both wingsuit and non-wingsuit jumps are soft and consistent (for me).
If you're in the Elsinore area, I have a couple Storms for demo purposes.
I think it's because I have the dacron lineset, which is more line bulk in the grommet. My new slider has 1-1/8" diameter grommets instead of the standard 1" ones, which solved the issue on freefall jumps and reduced the frequency from every wingsuit jump to about every other wingsuit jump I have trouble reaching the slider.
Brian
