jake95 0 #1 April 5, 2011 Is their a limit on how many times a reserve can be repacked. Quote Share this post Link to post Share on other sites
skydiverek 63 #2 April 5, 2011 Depending on the manufacturer. PD says 40 repacks, and then you have to send it to PD for recertification. Quote Share this post Link to post Share on other sites
theonlyski 8 #3 April 5, 2011 Quote Is their a limit on how many times a reserve can be repacked. Until it fails inspection And yes, PD does make you send it in to get a good factory once over after 40."I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
riggerpaul 1 #4 April 5, 2011 QuoteIs their a limit on how many times a reserve can be repacked. Adding some detail - PD says 40 repacks, or 25 DEPLOYMENTS. Aerodyne calls for testing after 20 repacks or 10 uses. Exactly what they mean by 20 repacks is a bit unclear to me. The manual says, "After 20 repacks (based on 6 month repack cycle)." Does that mean 20 repacks or 10 years or either/both or whichever comes first? They also call for testing after immersion in water, or "After any use in abnormal conditions." Quote Share this post Link to post Share on other sites
riggerrob 644 #5 April 6, 2011 QuoteQuoteIs their a limit on how many times a reserve can be repacked. Adding some detail - PD says 40 repacks, or 25 DEPLOYMENTS. Aerodyne calls for testing after 20 repacks or 10 uses. Exactly what they mean by 20 repacks is a bit unclear to me. The manual says, "After 20 repacks (based on 6 month repack cycle)." Does that mean 20 repacks or 10 years or either/both or whichever comes first? ..." ......................................................................... Whichever comes first. Quote Share this post Link to post Share on other sites riggerpaul 1 #6 April 6, 2011 QuoteQuoteIs their a limit on how many times a reserve can be repacked. Adding some detail - PD says 40 repacks, or 25 DEPLOYMENTS. Aerodyne calls for testing after 20 repacks or 10 uses. Exactly what they mean by 20 repacks is a bit unclear to me. The manual says, "After 20 repacks (based on 6 month repack cycle)." Does that mean 20 repacks or 10 years or either/both or whichever comes first? ..." ......................................................................... Whichever comes first. If so, it would have been clearer to say "20 repacks, 10 uses, 10 years, after immersion, after any unusual use". Does that cover it? Is there something wrong with that statement? I have written to them about, but nothing has changed, even though Dominic from Aerodyne replied and said the manual would be fixed. The current instructions are just not clear, and should be fixed to be clear. Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
