dragon2 2 #1 December 17, 2003 Anybody who can help me with this one? I have a Sony Vaio laptop with a dvd/cd-burner combo. Used to show up in Explorer as drive E. I have XP home. For some reason (we've been trying out various types of networks, and I've downloaded some XP upgrades too) now there are 3 drives showing, E/F/G. I think it split itself to a cd, dvd and cd-burner. I'm not really liking this, tho it's more of a nuisance then a real problem. Also I've noticed that all of a sudden any picture that's directly on my desktop (not in a dir) won't display in Explorer anymore, the rest works fine. Another weird thing was that the Winamp version I had would play 1 track then play on but the sound (Wave, only) would be all the way down in Volume Control. So no more music. Solved that one by getting Winamp3. Seems like a WinXP update causing all this? ciel bleu, Saskia Quote Share this post Link to post Share on other sites
CrazyIvan 0 #2 December 17, 2003 Easy to fix: Start WinXP in SAFE mode, then, go to DEVICE MANAGER (Right click on My Computer -> Properties -> Hardware tab and remove ALL THE CD/DVD/CDRW listed then reboot in normal mode.__________________________________________ Blue Skies and May the Force be with you. Quote Share this post Link to post Share on other sites
dragon2 2 #3 December 17, 2003 Nope no good. Not sure I even HAVE a safe mode anymore in XP home, so I did this in the normal mode. There's 2 drives listed, a SONY one and an AXV (SCSI). Uninstalling both then rebooting results in 3 drive letters again. Disabling the second drive results in 2, so at least a marginal improvement How come my laptop insists there's a SCSI drive in there too..? ciel bleu, Saskia Quote Share this post Link to post Share on other sites
CrazyIvan 0 #4 December 17, 2003 Yes..you CAN start in safe mode.__________________________________________ Blue Skies and May the Force be with you. Quote Share this post Link to post Share on other sites
dragon2 2 #5 December 17, 2003 OK, how then?? ciel bleu, Saskia Quote Share this post Link to post Share on other sites
CrazyIvan 0 #6 December 17, 2003 Press F5 while the computer is booting (you might keep tapping on it) a menu will appear.__________________________________________ Blue Skies and May the Force be with you. Quote Share this post Link to post Share on other sites
PhillyKev 0 #7 December 17, 2003 QuoteEasy to fix: Start WinXP in SAFE mode, then, go to DEVICE MANAGER (Right click on My Computer -> Properties -> Hardware tab and remove ALL THE CD/DVD/CDRW listed then reboot in normal mode. They'll just get rediscovered on next boot up. Just go into computer manager, then disk management. Right click and go to properties for the drives you don't want and change it to disabled in the drop down list. Quote Share this post Link to post Share on other sites
dragon2 2 #8 December 17, 2003 Right, forgot about that thanx. But, no good. 3 drives, back in force Although strangely in safe mode there was only the one. ciel bleu, Saskia Quote Share this post Link to post Share on other sites
CrazyIvan 0 #9 December 17, 2003 QuoteRight, forgot about that thanx. But, no good. 3 drives, back in force Although strangely in safe mode there was only the one. That's why you have to REMOVE ALL drives...so, after doing that they are still back?__________________________________________ Blue Skies and May the Force be with you. Quote Share this post Link to post Share on other sites
dragon2 2 #10 December 17, 2003 Yup I removed both of them. And both came back. The laptop really thinks it's in there, apperantly... What I meant was in safe mode I got only drive E but both hardware drives were visible, with the SCSI drive still disabled. In normal mode the Sony drive is both E and F. And no way that I'm going to reinstall XP... ciel bleu, Saskia Quote Share this post Link to post Share on other sites
CrazyIvan 0 #11 December 17, 2003 Interesting situation I have to say. Since is a laptop, that CD unit has to be removable, so, I'd remove it PHYSICALLY and repeat the procedure above, boot a couple of times WITHOUT the CD inserted, then, insert it, reboot and see what happens.__________________________________________ Blue Skies and May the Force be with you. Quote Share this post Link to post Share on other sites
