turtlespeed
Go figure
Uh huh,
Wouldn't expect anything less, would you?
Clicky
Positive Evaluations?
A new study shows that positive evaluations of President Bush on the network evening news have dropped from 56 percent during the Iraq war to 32 percent after the end to major operations was announced. The study, conducted by the Center for Media and Public Affairs, shows that CBS was the toughest on President Bush after major operations ended, with 77 percent negative evaluations, followed by ABC, with 67 percent negative evaluations. This as the Media Research Center is accusing ABC of burying its own poll, which, as we told you earlier this week, shows President Bush's job approval rating on Iraq rose 10 percentage points after Saddam's capture. ABC, the Center says, only referenced the poll for a few seconds with a small graphic Monday morning.
I'm not usually into the whole 3-way thing, but you got me a little excited with that. - Skymama
BTR #1 / OTB^5 Official #2 / Hellfish #408 / VSCR #108/Tortuga/Orfun
Do you ever get the feeling tht certain guys around DZ.Com do not get laid enough.
But with their constant obsession with politics.. it really is no wonder.
BWhahahahah!
Now you made me lie. I laughed aloud, my boss came over, and I had to tell him I was laughing at this.... Now he things I'm obsessed with tools. Or Tooling...;)
Tooling Schedule
The tools required for execution of each phase of the project are as detailed below. Note that this represents the minimum requirement. Teams may use other additional equipment wherever it will facilitate the work to be done.
Tools for Phase 1: Site Inspection
· Site layout plan
· Tape measure
· 1 x TV bracket mounting template
· Cable tester
· Power socket tester
· 1 x marker pen
Tools for Phase 2: Pre-installation
· 1 x Pinnacle Micro socket spanner (supplied by and for return to Pinnacle Micro)
· 1 x learner workstation security frame template (supplied by and for return to Pinnacle Micro)
· 1 x printer security frame template (supplied by and for return to Pinnacle Micro)
· 1 x 8mm flat screwdriver
· 1 x electricians flat screwdriver (2 – 3mm)
· 1 x No. 2 Phillips screwdriver
· 1 x 13mm flat spanner or socket with ratchet or T-drive
· 1 x 3m tape measure
· 2 x white board markers in different colours
· 1 x network stripper
· 1 x Power drill with 13mm chuck and hammer action
· 1 x 10m extension to suit drill
· 1 x 8mm wood drill bit for use with a power drill
· 1 x 8mm masonry drill bit
· 1 x 14mm masonry drill bit
· 1 x masonry centre punch
· 1 x 3 step or 6 step ladder
· 1 x pair of vice grips
· 1 x large square (600x400)
· 1 x medium weight ball peen hammer
· 1 x 3m plastic fish tape
· 1 x Stanley knife
· 1 x putty knife
· 1 x reel of adhesive insulation tape
· 1 x set broom, brush, dustpan, cloth etc. to clean up afterward
Tools for Phase 3: Hardware Installation and Commissioning
· 1 x CD for testing DVD
· 1 x Tape for testing VCR
· 1 x pair of side cutters
Tools for Phases 4 and 5 : Gauteng On Line Sign-off
None
t
It's the year of the Pig.
