With all due respect, and at the risk of sounding like a noob Skygod (I've never jumped), how is my question in any way confusing to a 15 year, 5000 jump, D-license holder?
The real answer? Because it's dumb. and has very little bearing on actual skydiving. What you end up jumping as a student depends on several factors, and PDs chart isn't one of them. The real factors range from what the DZ has available, to what is packed, to what the winds are like, to what harness will fit you.
If your body weight is 220, you'll be jumping a 280 or larger. The 260 is too small for you at that weight for your first few jumps. If you prove to be good with a canopy, you might end up on the 260 by jump 4 or 5, if not, you might not see the underside of the 260 until jump 10.
PD never intended anyone to analyze the complete set of data and make those types of comparisons because there's no reason to. What size canopy you jump isn't rocket science. You start off with a really big one, and downsize as you prove your ability to handle the faster wing.
You're sweating the small stuff. What you need to do is figure out a way to get to a DZ and make a jump ASAP. The first jump course (FJC) is designed to take someone who has never seen a parachute before, and teach them everything they need to know to safely make a first jump.
Forget about all this 'research' you're doing, because all that really matters is what the DZ you choose has in their FJC. They will teach you a very specific set of skills that will prepare to jump their brand of student rig, out of their chosen aircraft, following their dive flow for a first jump. Every DZ is slightly different in these ways, and if you muddle up your brain with 'ideas' and 'conclusions' you draw from this 'research', you're more likely to be confused or a pain in the ass during the classroom time.
The only way to be sure you're learning the correct info for the DZ you will be jumping at, is to learn it at the DZ.
labrys 0
The weights listed are the max weights PD recommends for each canopy. Those weights do not have a linear relationship with the canopy size. They may use exactly the same pattern for smaller sizes and make minor adjustments as they get larger.
Also, as canopies change sizes, line lengths change and performance changes. Performance is also non linear.
Again, this is all general speculation. Dave is really giving you good advice to just chill. The PD designers know what they are doing. So do the people who will teach you to jump.
sacex250 0
This is a skydiving forum, ask how big a camera you can take on your AFF or how many coach jumps you need to fly a velocity.
Thanks for making me laugh, that was funny. Okay, I'll ask a better noob question:
My exit weight is 220 lbs, would a Katana 107 be a good canopy for my first AFF jump? And, at what AFF level should I downsize to a 97?
There, that'll give Dave something to rant about.
I was wrong. Don't go to a DZ, or start jumping. Keep 'internet skydiving' poindexter, there are plenty of other canopy WL charts you can analyze and transcribe onto a spreadsheet, then you can stick your sliderule up your ass again, I'm sure the two of you will be very happy together.
That was a little over the top. I'm not sure even putting a smiley face emoticon after "you can stick your sliderule up your ass" would make it acceptable.
She was researching Alti's 3 months ago.
http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=3978070;#3978070
Now she is researching Navigator wingloadings.
Perhaps in a few years when all the research is done and all the t's are crossed she will decide to show up at a DZ and watch a live Tandem jump be done. A few years from there when she processes all the data she will shop around for the best deal. And finally about the time of their 20 year "first interest anniversary" she will find the most efficient route to the DZ and finally attempt to skydive.
just sayin'...
pchapman 280
Can someone make sense of this for me?
It does look a little messed up, even though PD has some of the most detailed info in the industry.
Nothing wrong with you asking, since you have no way of knowing better. Often, "read the manual" is right, but not all the time.
It just turns out that in this case it is over analyzing things, if the purpose is to figure out what canopy you should jump.
Still, I could see that if you were a drop zone owner about to buy student canopies, it would be a little confusing as the numbers wouldn't match one's own empirical experience.
Even though the jump in recommended wing loading going to bigger sizes is rather large, the lower vs. higher loadings can be PARTIALLY explained. Larger canopies are more docile at the same wing loading than smaller ones, so they can load a bit more. Also, there are practical limits to sizes, so for big guys there's a tendency not to supersize their canopy.
A smaller drop zone might well have one standard student canopy size for everyone, except perhaps a couple smaller canopies for the really light people, and maybe a couple bigger ones for the big boys. It isn't perfect, but different students will jump at quite a range of different wing loadings.
If they tell you something interesting, perhaps you could post it here.
nigel99 626
The OP is a Troll with an attitude.
just sayin'...
I was thinking troll. The knowledge of skydiving is impressive for a whuffo. Don't know how you figured out it was a she though?
DocPop 1
just sayin'...
All trolls are female. It is well-known. Look at petejones45.
~ CanuckInUSA
FLJB 0
Now researching Navigator wingloadings.
just sayin'...
My money is off of troll and onto lawyer or researcher for a law firm or insurance firm looking for something
![[:/] [:/]](/uploads/emoticons/dry.png)
My money is off of troll and onto lawyer or researcher for a law firm or insurance firm looking for something???
I will have to second that
billvon 3,120
Smaller canopies are faster than big ones even at the same loading - thus the lower loading recommended for small canopies.
The 254lb limit is a holdover from TSO C23c (I believe) that limited ALL parachute equipment to 254lbs. Thus it often shows up in odd places.
The numbers above that are all likely similar loadings, just with rounding errors giving you slightly different loadings.
sacex250 0
I have read and studied the SIM, and I can't find the part about how you have to have failed pre-algebra to qualify as a skydiver. Really, I find it disappointing that something as fundamental to skydiving as the weight to canopy size ratio (wing-loading) would cause experienced jumpers to run for cover. What happens when someone wants to discuss the fuel mileage of their cars?
If anyone just thinks I'm being pedantic (look it up), you can thank John LeBlanc at Performance Designs for that. I've found that PD has the best information on their website, and every article written or video made by LeBlanc does an incredibly clear and thorough job of intellectually discussing skydiving concepts without talking down to anyone about it. I was obviously mistaken when I thought "average" skydivers would have the same grasp of basic skydiving concepts as he does. While I know that other canopy manufacturers produce quality products, I think I would find it difficult not purchasing PD canopies as my first gear.
That said, my OP and my "research" was never intended for selecting a first-jump canopy. I've simply been familiarizing myself with different canopies from different manufacturers, how else does one learn the differences between a Fusion, Stilletto, Safire2, or Omni?
And, if that seems wrong to you, let me just say that it's USPA, DZO's, and lawyers who have determined that I am solely responsible for my own safety, training, and equipment. The shut-up-sign-the-form-and-pay-me-money-attitude of the skydiving industry, SO PROFOUNDLY DEMONSTRATED IN THIS THREAD, requires that I participate in this sport with nothing less than the desire to become an expert in every area of skydiving knowledge. What I don't know could kill me or someone else. It's people like "davelepka" and "likestojump" that leave me wondering if perhaps my money would be better spent on scuba diving trips or building a sport plane. Simply, skydiving interests me, skydivers don't; well, except those like John LeBlanc who clearly know what they're talking about, and can do so at my intellectual level, I actually passed pre-algebra!
sacex250 0
Perfect example of what I was talking about in my last post. This is a completely idiotic post from a highly experienced skydiver and moderator. It's outright embarrassing!
The 254 limit is the STUDENT maximum recommended limit, the Navigator 260's MAXIMUM weight limit is listed as 336 pounds! What does TSO C23c have to do with PD's 254 pound recommended weight limit for students? Answer, NOTHING!
The inconsistencies on the chart are not rounding errors, and thanks to my "research" I'm more than aware that a smaller canopy is more maneuverable than a similarly designed larger one at the same wing-loading.
I guess I should start planning that scuba trip to Micronesia.
sacex250 0
Since we are all morons here, why don't you email John LeBlanc at PD ? Straight to the source...
To quote your own profile:
"And I LOVE telling people how it really is - which usually involves telling them that they are whiny spoiled brats. I also like to rub people's nose into the extremely one-sided, borderline hypocritical statements that so many like to make."
You don't have a monopoly!
DocPop 1
...how else does one learn the differences between a Fusion, Stilletto, Safire2, or Omni?
Jump them.
Just a thought, whuffo.
~ CanuckInUSA
Dude will you do my math homework? This is a skydiving forum, ask how big a camera you can take on your AFF or how many coach jumps you need to fly a velocity. You are making my head hurt, and it appears you are confusing Davelepka, which usually seems pretty hard to do, so I guess congratulations but easy with all the numbers.
And don't forget the world would be a better place with less math in it so try being part of the solution and not part of the problem. Good luck on your jumps, dude. And don't read this forum too much before you get some jumps (or even after), I think there might even be a 200 jump minimum to post in Gear and Rigging.
Jump whatever they give you, Nav's aren't all that different between .07 and 1.1 anyway, just don't fly it into anything any you will be fine, flaring is kind of optional on those
