Glipazide 0 #1 January 10, 2004 I am using bulletproof and CuteFTP. While loading CuteFTP, it asks for MY FTP Server name... where in XP can I find this out? Or do I use my IP Addy while using port:21 ? Clinthttp://sexygirlabs.com/url] Quote Share this post Link to post Share on other sites
souleh 0 #2 January 11, 2004 It's your FTP server's address (either hostname or IP). In your case, just use your computer's IP. If you just want to access local server, use the address 'localhost' (ip 127.0.0.1). If you want other people to access it and you're directly net facing, do: start->run type 'cmd', press enter type 'ipconfig' at the prompt This will display your computer's IP addresses. Hope this helps 'buttplugs? where?' - geno Quote Share this post Link to post Share on other sites
n2skdvn 0 #3 January 11, 2004 Also if you are behind a router make sure you set your dmz host to that computers ip address.if my calculations are correct SLINKY + ESCULATOR = EVERLASTING FUN my site Quote Share this post Link to post Share on other sites
Glipazide 0 #4 January 11, 2004 Gotcha, thanks guys! Clinthttp://sexygirlabs.com/url] Quote Share this post Link to post Share on other sites
wildcard451 0 #5 January 11, 2004 You may not want to dmz your ip since that will open every port to the outside world. You may just want to forward port 21. Just my .02. Quote Share this post Link to post Share on other sites
