FliegendeWolf 0 #1 January 25, 2004 Sooo...I just upgraded my computer to windows 2000 and all seems to be fine except for one thing: I am getting no sound from WAV files, but I am getting sound from windows media files. I use a C-Media PCI device. I've tried updating the drivers for the device (and Microsoft lists it as 2000 compatible). Any idea as to why this might be happening?A One that Isn't Cold is Scarcely a One at All Quote Share this post Link to post Share on other sites
Faber 0 #2 January 25, 2004 did you upgrade from 98 or 95? i had a similar problem as i did it to get xp from 98. i simply formated it reinstalled from cd then i had no problems. you could also try the repair thing on the cd(if the 2000 has it). Stay safe Stefan Faber Quote Share this post Link to post Share on other sites
CrazyIvan 0 #3 January 25, 2004 Have you checked VOLUMEN CONTROL?, usually there is a panel for WAV/MP3 maybe is muted or very low.__________________________________________ Blue Skies and May the Force be with you. Quote Share this post Link to post Share on other sites
FliegendeWolf 0 #4 January 25, 2004 Yes, the volume is up on the control panel.A One that Isn't Cold is Scarcely a One at All Quote Share this post Link to post Share on other sites
CrazyIvan 0 #5 January 25, 2004 Have you installed the service packs?__________________________________________ Blue Skies and May the Force be with you. Quote Share this post Link to post Share on other sites
LuvToFly 0 #6 January 25, 2004 A couple of things: 1) Are you saying that your Window media player opens, plays wmv files, but not WAV files? What happens when you try to play them. Does it appear to be playing them, or do you get an error message and if so, what does the message say? 2) I saw that you answered the question about the volume control, and saw that you said you checked it. - Just want to be sure we are talking about the same thing here - We're talking about the volume adjustment window where you see several vertical sliders - from left to right named: Master Volume / Wave Balance / SW Synth Balance... etc This is where the wave balance volume control needs to be full up - Also, short of the Service Pack upgrade, I'd suggest you up grade your Windows media player to the latest version. If you upgraded using a Windows 2000 CD, you DEFINITELY do not have the latest version. T.B. (Geek) "The helicopter approaches closer than any other to fulfillment of mankind's ancient dreams of a magic carpet" - Igor Sikorsky Quote Share this post Link to post Share on other sites
LuvToFly 0 #7 January 25, 2004 Some custom sound cards install their own volume center - which in effect, replaces what used to be controlled exclusively by the Windows panel. Make sure that your sound card software did not install a volume center of it's own. If it did, you need to make adjustments in there - Also, when you said you installed drivers - did you install the full recommended setup for the sound card - or did you just install the drivers? Some have both - and it may make a difference depending on what the card is looking for - T.B. (Geek) "The helicopter approaches closer than any other to fulfillment of mankind's ancient dreams of a magic carpet" - Igor Sikorsky Quote Share this post Link to post Share on other sites
FliegendeWolf 0 #8 January 25, 2004 DOH! Problem solved. Strange: when I first upgraded the computer, the sound was fine. I assumed it was only the WAV files that were not processing correctly because I had watched a few movies with no sound issues. So I tried watching them again...no sound. So I went to the back of the computer and switched my speaker jacks. That fixed it. I wonder why that happened? A One that Isn't Cold is Scarcely a One at All Quote Share this post Link to post Share on other sites
britboynz 0 #9 January 25, 2004 Fill out the service request form (like we ask all our users to!) & wait for tech support to contact you. Glad ur problem is sorted SYSTEM PROBLEM REPORT This is a form to make the reporting of problems consistent, allow records of problems to be kept, and a method of discouraging users from reporting faults in the first place. -------------------------------------------------------------------------------- Your name? ___________________ Your login name? ____________________ The date? __/__/__ The date the problem first occured if different? __/__/__ Problem Severity: Minor__ Minor__ Minor__ Minor__ Which machine? ____________________ Which area appears to be at fault? Communications__ Disk__ Base Unit__ Network__ Keyboard__ Screen__ Mouse__ Everything__ Don't Know__ Is it plugged in? Yes__ No__ Is it switched on? Yes__ No__ Has it been stolen? Yes__ No__ Have you tried to fix it yourself? Yes__ No__ Have you made it worse? Yes__ Have you read the manual? Yes__ No__ Are you sure you've read the manual? Yes__ No__ Are you absolutely certain you've read the manual? Yes__ No__ Did you understand it? Yes__ No__ If `Yes' then why can't you fix it yourself? __________________________________________________ __________________________________________________ Is the equipment unexpectedly noisy? Yes__ No__ If `Yes' what sort of noise? Grinding__ Rattling__ Whirring__ High pitched whine__ Sound of disk head scouring disk__ Strange, out of tune whistling or humming__ Is there a smell of burning? Yes__ No__ If `Yes' is the equipment on fire? Yes__ No__ Is the fault repeatable? Yes__ No__ What were you doing (with the equipment) at the time the fault occurred? __________________________________________________ __________________________________________________ If `nothing' explain why you were logged in: _________________________________________________ Are you sure you aren't imagining the problem? Yes__ No__ Do you have any independent witnesses of the problem? Yes__ No__ Describe the problem: __________________________________________________ __________________________________________________ Now, describe the problem accurately: __________________________________________________ __________________________________________________ Speculate wildly about the cause of the problem: __________________________________________________ __________________________________________________ Can't you do something else, rather than bothering me? Yes__ No__ Quote Share this post Link to post Share on other sites
